b16a ctr pistons hondata ecu t04e?
Old Feb 8, 2002 | 10:38 AM
2 litre EG's Avatar
Default b16a ctr pistons hondata ecu t04e?
i have a 90 civic hatchback with a b16a i wanted to know what you gys think a b16a with ctr pistons rods ctr valvetrain cams.with a hondata ecu 2b and a revhard stage 2 turbo kit t3/t04e.. what do you gu think it will hit???good idea or no
Old Feb 8, 2002 | 10:54 AM
racerxadam's Avatar
Default Re: b16a ctr pistons hondata ecu t04e? (allm0t0rsir)
ctr pistons in a b16a yields somewhere in the 11:1 compression ratio. kinda high to go turbo.
Old Feb 8, 2002 | 11:05 AM
PresSI's Avatar
Default Re: b16a ctr pistons hondata ecu t04e? (racerxadam)
racerx, when you were talking about the compression being to high for turbo, i just need a little clarification. What is the rule of thumb when it comes to compression ratio and boost? Im just thinking that a real ctr runs a 11:1 ratio right?and im sure someone has put a turbo on a ctr. I am assuming that they lower the compression by some means right. Sorry for my ignorance, im just trying to learn. I did a search under compression ratio and came up with very little.
Old Feb 8, 2002 | 11:11 AM
racerxadam's Avatar
Default Re: b16a ctr pistons hondata ecu t04e? (PresSI)
i'm just going by what i read on here. generally people are running between 8.5:1 to 10:1 compression. as the compression gets higher it becomes more difficult to maintain steady cylinder pressures under boost (pinging or knocking). the higher compression ratio engines can handle boost it is just generally less boost or you have to have very good tuning to prevent detonation.
Old Feb 8, 2002 | 11:13 AM
PresSI's Avatar
i see...thanks
Old Feb 8, 2002 | 11:16 AM
boosted hybrid's Avatar
With a 11:1 comp ratio your tuning window is severly cut down. The bright side to things is that you dont have to run as high of boost levels to achieve decent hp numbers. It really all comes down to tuning. I know that Stoopid on clubsi.com regularly turns out high compression forced induction engines that are running 10psi on pump gas. You should chat with him...check the Got Boost forum...he can give you answers that you need with your set-up.
B16A CRX
Apr 6, 2007 06:03 AM
duRritztiNy
35
May 16, 2003 10:36 PM
egchan
Feb 27, 2003 12:30 PM
vspec12
May 14, 2002 06:08 PM
