PCV steaming/smoking
Old Jun 3, 2005 | 04:56 AM
jolt-tsp's Avatar
Default PCV steaming/smoking
Was autocrossing my Civic, seals blew on the t25 turbo, I'm puffing white smoke or steam out the tailpipe, also coming out of the crankcase and valve cover. I figure oil and water mixed in the turbo. I replaced the head gasket (just in case) and the turbo. Still smoking out the crankcase, then saw oil coming out the compressor housing, okay another bad turbo. Well, I took the coolant lines off the turbo, and changed the oil, just to be sure the crankcase stopped with the smoking. Well it didn't. I let it run for about 5 minutes that way. Still never stopped.
Is it possible that I still had enough water left in the engine that it could steam for 5 minutes veven after I drained and changed the oil? Or might there be another problem? The only other thing I can think of is the head possibly warped, and coolants still mixing with the oiil in that area. I'm really hoping thats not it though
Old Jun 5, 2005 | 08:05 AM
jolt-tsp's Avatar
Default Re: PCV steaming/smoking (jolt-tsp)
Well I did a compression check. 1-4 = 60, 60, 80, 185. So I'm guessing a warped head explains everything. Anyone know a good machine shop in the dfw area?
Old Jun 7, 2005 | 01:47 PM
jolt-tsp's Avatar
Ugh, okay, it's not warped. I went all the way across the block and head with a .0015" feeler and a straight edge and never made it through. Anyone have any clue why my compression is a suck across 3 cylinders and I'm mixing oil and coolant? Please help, I'm totally at a loss.
Old Jun 7, 2005 | 01:51 PM
Stoich EG2's Avatar
you blew your oil rings homie and probably the other rings. the smoke is probably from blow by.
Old Jun 7, 2005 | 01:52 PM
Stoich EG2's Avatar
Default Re: PCV steaming/smoking (Advan06)
to make sure you blew your oil rings, do the compression test again, this time, open the oil cap and listen for air coming up
Old Jun 7, 2005 | 02:40 PM
jolt-tsp's Avatar
Can't beleive I didn't think about that. I just immediately assumed the smoke was water burning off. Makes a ton more sense now
Old Jun 8, 2005 | 05:07 AM
jolt-tsp's Avatar
Is it true that honing is required only if you can feel an imperfection, or is you have visual imperfections that go from top to bottom of the cylinders walls? My cylinders look uber-clean. Not one blemish I can see. So I'm guessing I don't need to hone?
Old Jun 8, 2005 | 06:40 AM
wilsel's Avatar
I would do it anyway, you can't see every imperfection.
lookout22
May 17, 2009 07:37 PM
smoovy
Apr 19, 2009 11:09 AM
JUST2SPOOL
Feb 7, 2006 01:13 AM
B18badboy
May 10, 2004 01:50 PM
