Possible to modify DRAG's downpipe/manifold to prevent boost creep...?
Old Feb 8, 2002 | 10:14 AM
DSF's Avatar
DSF
Default Possible to modify DRAG's downpipe/manifold to prevent boost creep...?
Ok, the general concensus is that when stepping up to a 3" exhaust, the design of the DRAG manifold encourages boost creep because of the location of the wastegate. Well, sloaccord's Kiwi manifold https://honda-tech.com/zerothread?id=126142 got me thinking. What if you closed off the wastegate opening in the DRAG manifold and welded a new wastegate pipe/flange on the downpipe flange at the location of the internal wastegate's opening in the turbine housing? Make sense? The wastegate would see exhaust pressure from all cylinders and as long as the discharge hole was large enough, creep shouldn't be a problem. Of course you could only do this with the 5-bolt flange. Sound possible?
[Modified by DSF, 2:35 PM 2/8/2002]
Old Feb 8, 2002 | 07:44 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Possible to modify DRAG's downpipe/manifold to prevent boost creep...? (DSF)
yes,it will work very well
stocker2shocker91
Oct 26, 2006 10:45 PM
Griffin@Camtech
Jul 8, 2004 07:14 AM
platinum00
Sep 22, 2003 10:39 AM
boosted3g
Dec 7, 2001 02:17 PM
LsTurbo91
Oct 27, 2001 05:59 PM
