Rear disc assembly.
Old Jun 2, 2005 | 08:30 PM
BaGGed HoNDa's Avatar
Default Rear disc assembly.
I have a 91 LX 4dr that has rear drums and I found a 92 EX with rear discs. But the cool part is, I can get the entire assembly for $75 which I think is a damn good deal. Can someone please list everything I will need to get off the car to convert mine? I know the entire rear control arm and everything needs to come, and the brake proportioning valve. but it would really help if I had a list.
(sidetopic) Im also getting the 92-93 front bumper for 150 which has oem fog lights installed.
Thanks.
Old Jun 2, 2005 | 08:36 PM
momstaxi's Avatar
Default Re: Rear disc assembly. (BaGGed HoNDa)
that is a good deal, as far as list, i dont really have one but just unbolt the whole rear trailing arm assembly and unbolt the lower control arm and then disconnect the upper arm where it bolts to the body of the car, then you will be golden, also unhook the brakeline as close to the car as you can incase you need a certain fitting for the disc brakes
you will also have to disconnect the ebrake cables from the ebrake lever inside the car and then work them out from over the exhaust heat shielding. then just clip the wire for the abs because you wont be able to use that...
Old Jun 2, 2005 | 08:51 PM
ok cool, thanks for your help. Now about that front bumper, how rare is that with the oem foglights? i've never even seen a 92-93 bumper with them.
Old Jun 2, 2005 | 08:59 PM
another thing I just thought of, are the master cylinders the same or should I buy the one off this car too?
Old Jun 3, 2005 | 07:03 AM
bump..
Old Jun 3, 2005 | 07:32 AM
Now about the brake prop valve. I've been reading that the 4th gen EX valve that the car has, I cannot use due to the fact that that car has abs and mine doesnt. Could I use my stock 91 LX prop valve with the rear disks or should I go try to find a DA Integra 40/40 prop valve?
Old Jun 3, 2005 | 12:33 PM
NAiL05's Avatar
hey i got this from cb7tuner.com. They have good tech and DIY's on 4 gen accords. This is a drum to disk conversion on a 92 LX 2 door with drums. i hope this helps u out man. That persons car also has OEM foglights if u guys r wonderin what it looks like on a 4 gen.
http://www.cb7tuner.com/vbb/sh...rsion
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
civicminded3111
Jul 9, 2006 08:29 PM
cliff666
Jun 20, 2005 03:08 PM
soundbomber
20
Jan 20, 2004 02:29 PM
DOHC-DX
11
Sep 18, 2002 06:47 AM
