b16a2 or b18b? need some help
Old Jun 2, 2005 | 07:47 PM
slow_redcivic's Avatar
Default b16a2 or b18b? need some help
i am looking to put a lsvtec into my 95 civic but my question is do i wanna get a b16a2 swap and then put the ls block on or do i want to buy the b18b swap and put the b16a2 head on. ive read that the b16a2 trannys are better then the b18b so i was thinking buy a b16a2 complete swap and then put a b18b long block onto it and sell the b16a2 block. let me know what you guys think. also i plan on boosting it. ive heard from different guys in the area i'll be making around 300 and ive heard 250 to the wheels tuned at 8-10 psi. let me know what you guys think and if you have any suggest include those too.
Old Jun 2, 2005 | 08:03 PM
civictildeath's Avatar
Default Re: b16a2 or b18b? need some help (slow_redcivic)
http://www.c-speedracing.com/h...c.php
if you use the B16 block, you will have little torque
if you use the B18 block, you will get more torque because of 12 mm difference in stroke
B18 block, B16 head
Old Jun 2, 2005 | 08:10 PM
osideracer1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_redcivic &raquo;</TD></TR><TR><TD CLASS="quote">i am looking to put a lsvtec into my 95 civic but my question is do i wanna get a b16a2 swap and then put the ls block on or do i want to buy the b18b swap and put the b16a2 head on. ive read that the b16a2 trannys are better then the b18b so i was thinking buy a b16a2 complete swap and then put a b18b long block onto it and sell the b16a2 block. let me know what you guys think. also i plan on boosting it. ive heard from different guys in the area i'll be making around 300 and ive heard 250 to the wheels tuned at 8-10 psi. let me know what you guys think and if you have any suggest include those too. </TD></TR></TABLE>
y not consider the amount of $$$ it will take to swap in either & how much extra it will be to convert it to ls/vtec later on down the road. I would think that it would be easier to swap in the b16 first then get the ls bottom. I think this would be the cheaper route (someone please correct me if im wrong cuz i probably am).
Old Jun 2, 2005 | 10:55 PM
oneforce's Avatar
Default Re: b16a2 or b18b? need some help (osideracer1)
You are right on the money...buy a complete b16 and throw the ls bottom end later..You wanna have short gearings when doing a ls/vtec swap, but if you are going the turbo route, why bother with the ls/vtec? i suggest ls turbo, cheapest way to be fast. ls is already low compression, good for turbo 8-10lbs. tuned for about 250 hp. get a ls and turbo that baby
Old Jun 3, 2005 | 12:09 AM
B16aDasher's Avatar
Default Re: b16a2 or b18b? need some help (oneforce)
it would be easier to swap in the b18b with a b16a tranny. Then later just swap heads.
Old Jun 3, 2005 | 05:40 AM
spoolingb20's Avatar
Default Re: b16a2 or b18b? need some help (B16aDasher)
Why don't you piece together the motor and tranny that you want?
Old Jun 3, 2005 | 07:16 AM
Default Re: b16a2 or b18b? need some help (spoolingb20)
What would the power diffence be if i went with a straight ls swap or a lsvtec swap. ive heard its little to nothing. also what size of a turbo am i gonna want to put on there i've been looking at t3/t04e's are those to small? let me know.
Old Jun 5, 2005 | 01:25 AM
Egone's Avatar
get the b18 i was cruising with some friends tonight and we deceided to have some fun and my b18a pulled way harder but my friends motor is the first gen b16a
Old Jun 5, 2005 | 03:53 AM
civichatch95md's Avatar
Default Re: (Egone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_redcivic &raquo;</TD></TR><TR><TD CLASS="quote"> ive read that the b16a2 trannys are better then the b18b </TD></TR></TABLE>
Not always true, Ls tranny are geared taller much better suited for turbo applications unless you are only interested in drag racing where the tighter ratios in the B16 will suit you better.
For exact specs on tranny i suggest picking up this months D sport (new mag as far as ive seen) but they did a ratio break down in honda trannys. from individual gears to final drive ratio.
If you are gonna boost it either way skip the vtec, get a LS and spend the money you would have on the vtec on things like ecu tuning, fuel, or ignition upgrades. Lot more power to be had there.
Old Jun 5, 2005 | 05:56 AM
RaYnE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolingb20 &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you piece together the motor and tranny that you want?</TD></TR></TABLE>
best answer so far..this way would be the most inexpensive
LiQale
May 29, 2008 06:43 PM
Sketch_hs
Oct 8, 2004 08:09 AM
allmotorej8
May 19, 2004 07:44 AM
avividmemory
Nov 26, 2002 02:39 PM
enabi
Sep 29, 2002 09:33 PM
