HELP ASAP! Cant remove stud! Calling all non vtec d-series guru's
Old Jun 2, 2005 | 01:01 PM
92CHB's Avatar
Default HELP ASAP! Cant remove stud! Calling all non vtec d-series guru's
Okay i was stupid and over tightened a valve cover nut and snapped the stud. Its not a probelm gettting the bolt loose...the problem is i cant get the bolt OUT. I loosend(sp?) the bolt and it moves up and down freely but it wont slide/pull out of the hole in the cam bearing cap. I am lost for ideas how to get it out, is there any type of retaining washer, dowel, or spring holding it in from being pulled out. I dont have to remove the whole rocker arm assembly i hope. Oh yea this is on a D15B7 motor, its the stud by the oil cap. Please help me this is the only thing stopping me from completing my project. THANKS!
Old Jun 2, 2005 | 01:13 PM
NotSoSimple's Avatar
Default Re: HELP ASAP! Cant remove stud! Calling all non vtec d-series guru's (92CHB)
So its completely loose? Maybe loosen it some more with a bit of pressure upward (like taking it out). Take a look at a new stud and reverse engineer it.
dpkelly's Avatar
You have to loosen all bolts for the rocker arm assembly according to the sequence listed in a helms or chilton's manual. Otherwise, you may warp part of the rocker arm assembly. The same can be said about tightening them. Make sure you have a torque wrench. Good luck.
Old Jun 2, 2005 | 01:28 PM
92CHB's Avatar
okay i'll try loosening them all.
Old Jun 2, 2005 | 01:47 PM
Otherguy's Avatar
NASIOC.com
Default Re: (92CHB)
pictures
Old Jun 2, 2005 | 02:16 PM
92CHB's Avatar
EUREKA It worked!!! Thanks dpkelly!!!!!
chasebur
Honda CR-V & Element
Jan 7, 2019 05:25 PM
lmike6453
Jun 30, 2008 07:31 AM
cc11386
Nov 2, 2005 01:31 PM
Methane2k2
Dec 15, 2004 12:57 AM
SL!M
Jun 2, 2003 06:20 PM
