b18c b16
I just got a jdm b18c block (gsr) and im going to put my b16 head on it with a set of ITR cams and jun cam gears. When i do this what head gasket should i get, im getting arp head studs which ones should i get? What timing belt do i get? Thanks for the help guys.
b16 head studs
i usually just buy an oem HG...unless ur scrounging for every bit of extra compression aftermarket is not really necessary...u can still remove the middle layer of the oem one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i »</TD></TR><TR><TD CLASS="quote">B-series vtec head gaskets are the same... use a GsR timing belt and GsR ARP headstuds</TD></TR></TABLE>
CHRIS NAILOR IS A SCAMMER!!!
Scammed me for STI seats and then these seats shown below. See original thread here:
https://honda-tech.com/zerothread?id=1346370
GOT THE SEATS TODAY AND THEY ARE ****! ONE SEAT IS IN DECENT SHAPE AND THE OTHER IS FUCKED. I SET THE TWO SIDE BY SIDE TO SHOW HOW BAD THE OTHER WAS.
THIS DID NOT HAPPEN IN SHIPPING!!! THE BOTTOM BRACKET IS BENT AND HAS SCRATCHES IN THE CREASES THAT COULDN'T HAVE BEEN CAUSED BY SHIPPING!! THEY WERE SENT LIKE THIS, PERIOD.
How are you gonna make this right, Nailor?
Your clock is ticking.
IntegraGSR(-1)
May 28, 2006 05:22 PM
IntegraGSR(-1)
May 26, 2006 01:57 AM
