99 Honda Accord Check Engine Light-Please Help!!!
Old Jun 2, 2005 | 11:21 AM
9hatchman4's Avatar
Default 99 Honda Accord Check Engine Light-Please Help!!!
I was thinking about buying a 99 Honda Accord for my dad, but It's throwing a code, and the maintenance light is on. I know in Integra's there's a little jumper harness over by the passenger feet area that you can check the code on, but I'm not sure how to check it on here. Also the maintenance light is on, I figure it's because of the code, but I'm not sure. In Integra's there's just a little button under the dash that you can turn it off with, but I looked and didn't see one on the accord. Cool, any help would be appreciated, I'm gonna do some more research and see if I can find anything else out. Also does anyone have a list of codes like on the other model forums, thanks again
Old Jun 2, 2005 | 11:28 AM
AccludePower's Avatar
Default Re: 99 Honda Accord Check Engine Light-Please Help!!! (9hatchman4)
im not to sure about the engine light but im pretty sure that the maintness light is on from not being reset after an oil change, have you tryed to reset the maintess light at all?
philadd's Avatar
For the CEL,
Use the plug described here:
https://honda-tech.com/zerothread?id=993196
Procedure is still the same.
http://www.c-speedracing.com/faq/06.php
Link for codes:
http://hybrid2.honda-perf.org/tech/codes.html
Maintenance light:
https://honda-tech.com/zerothread?id=989493
Old Jun 2, 2005 | 12:49 PM
9hatchman4's Avatar
Thanks guys, I got the maintenance light figured out and I ran the code, it's the oxygen sensor, do any of you know if these year accords have one or two oxygen sensors? Thanks again for the help
Old Jun 2, 2005 | 01:19 PM
9hatchman4's Avatar
Bump for help
Old Jun 2, 2005 | 01:41 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatchman4 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys, I got the maintenance light figured out and I ran the code, it's the oxygen sensor, do any of you know if these year accords have one or two oxygen sensors? Thanks again for the help</TD></TR></TABLE>
What's the code, that will narrow down the problem. (there are several for the o2s)
Old Jun 2, 2005 | 02:40 PM
YeuEmMaiMai's Avatar
v6 accord has 2 one for each bank of cylanders
Old Jun 2, 2005 | 03:05 PM
Chiovnidca's Avatar
Default Re: 99 Honda Accord Check Engine Light-Please Help!!! (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">v6 accord has 2 one for each bank of cylanders</TD></TR></TABLE>
I think they have 3.
Old Jun 3, 2005 | 06:52 AM
deserthonda's Avatar
they have 3
Old Jun 3, 2005 | 10:30 AM
iam7head's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">they have 3</TD></TR></TABLE>
one at each side of the header, and the last one in the middle of the cat converter.
four banger have two one precat and one in the cat.
make sure you only buy oem oxygen sensor, even the bosch oem replacment sensor will not clear the cel code.
Old Jun 3, 2005 | 12:13 PM
NAiL05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">one at each side of the header, and the last one in the middle of the cat converter.
make sure you only buy oem oxygen sensor, even the bosch oem replacment sensor will not clear the cel code.</TD></TR></TABLE>
BigT2424
Jul 19, 2016 02:45 PM
Joserey90
Sep 17, 2010 06:12 PM
crazyrawb22
Oct 13, 2006 07:57 PM
tedog69er
Mar 1, 2006 06:45 AM
