searched.. and about to set my car on fire
the idle problem!!!
its an auto
i changed the coolant temp sensor.. the IAC...
used to just rev in park and neutral but now it revs in drived and reverse
and if i drive for long.. i guess when it warms up more.. it revs fast as hell when im at a stop light.. or brake under like 10 mph.. and its drivin me friggin nuts.. im bout to sell this **** just because of it.. lol
what else can i do.. im bout to spend the money to take it to honda
its an auto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hAILO »</TD></TR><TR><TD CLASS="quote">seems like you need to change the oil in your tranny. </TD></TR></TABLE>
LOL..your funny!^^^
bring it to honda we'll fix it for you!
LOL..your funny!^^^
FITV
bubbles in coolant
vacuum leak
Never ever mention that you have an auto tranny on Honda Tech. It doesn't matter anyway. Blown lock up solenoids could cause slight idle problems, but not like you're describing.
bubbles in coolant
vacuum leak
whats a lock up solenoid?
and when i left off the gas it kinda of boggs like it was stick.. u know how when ur in first or any gear in a stick and when u rev high and nnot shift it boggs slow.. it feels like that...
thanks..
thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">FITV
bubbles in coolant
vacuum leak
Never ever mention that you have an auto tranny on Honda Tech. It doesn't matter anyway. Blown lock up solenoids could cause slight idle problems, but not like you're describing.</TD></TR></TABLE>
the plunger just needs to be tightened in
bubbles in coolant
vacuum leak
thanks im goin through the list right now..
no vaccum leaks that i noticed
I just went out and got a new PCV valve.. what model do you guys have? (replacin this didnt help-old one was shot though.)
Flushing and draining the coolant now.. checkin for bubbles
Going to check voltage after the coolant gets back in
*in park it idles eratic.. and then i put my figer over the top hole in the Intake manifold...and the idle goes normal*
* also if i put it in drive it will go normal(without figer over hole) but it only goes normal with the heat on full blast.. and if i turn it to 1 2 0r 3 it idles erratic*
hopefully someone can help me?
I have the 1.6 ex vtec... how do i take of the part where i can tighten the screw all the way down like it stats in that write up? is that from a different engine.. ?
Highwind
Honda Civic (2001 - 2005)
Apr 1, 2011 09:32 AM
