87 Civic Si needs a swap
Old Jun 2, 2005 | 10:51 AM
mikes99si's Avatar
Default 87 Civic Si needs a swap
what's the easyest swap for a 87 civic si. Old engine is worn out just wondering if there is a jdm engine that is a good replacement.
Old Jun 2, 2005 | 10:54 AM
SwissChEz82's Avatar
Default Re: 87 Civic Si needs a swap (mikes99si)
I would say find a D16a1 from an 88-89 Integra, they swap right into that chassis.
Old Jun 2, 2005 | 04:08 PM
mikes99si's Avatar
Default Re: 87 Civic Si needs a swap (SwissChEz82)
just the motor or the whole drive train
Old Jun 2, 2005 | 06:28 PM
jlicrx's Avatar
you want the 86-87 Integra D16A1 - it is the one that is compatible - 88-89 D16A1 has electronic advance distributor and is a lot more work to get wiring right - you will need engine, transmission, axles, knuckles/hubs, shift linkage and ECU from Integra - you could also use the JDM browntop ZC - it is 128hp where D16A1 is 112hp
Old Jun 2, 2005 | 07:51 PM
bagpipe goatee's Avatar
i can't believe nobody has plugged redpepperracing.com yet. well, go there, go to the forum faq for engine swaps. they deal just with the 84-87's.
Old Jun 2, 2005 | 08:31 PM
Losrocket_'s Avatar
Default Re: (bagpipe goatee)
Dont waste your time with the D16a1. Dont get me wrong its a solid swap and all but if your going to get into a swap go B series. I had an '87 HB Si w/ B20vtec in it and damn that car kicked ***.
I was originally going to go with a D16a1 and happen to get a hook up for a complete B16 swap w/ mounts from a HASport '86 Civic. Im glad i did
Old Jun 3, 2005 | 06:00 AM
mahatma's Avatar
Default Re: (Losrocket_)
https://honda-tech.com/zerothread?id=1258316
^ Talk to that guy
Old Jun 5, 2005 | 06:12 AM
mikes99si's Avatar
I really don't want to change everything just looking to see if there was a jdm replacement engine that will drop in.
Old Jun 5, 2005 | 12:17 PM
jdmEFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Losrocket_ &raquo;</TD></TR><TR><TD CLASS="quote">Dont waste your time with the D16a1. Dont get me wrong its a solid swap and all but if your going to get into a swap go B series. I had an '87 HB Si w/ B20vtec in it and damn that car kicked ***.
I was originally going to go with a D16a1 and happen to get a hook up for a complete B16 swap w/ mounts from a HASport '86 Civic. Im glad i did </TD></TR></TABLE>
...out of curiousity...how much did you pay for your swap?? I really "dig" the AT body-style and would like to drop a B-series in it. More specifically, how much was all the swap related parts (minus the motor and trans). TIA.
...Sorry...don't mean to thread jack.
nolanwalter12
Honda Civic (2006 - 2015)
Jul 8, 2014 06:03 AM
baker1218
Classic Hondas
Aug 14, 2009 11:54 AM
rz514
Jun 21, 2006 02:25 PM
EF_generation
Sep 9, 2004 05:18 PM
91 civic
Jan 24, 2004 10:02 PM
