Popping Noise, need some advice..
Old Jun 2, 2005 | 07:36 AM
citrus3000psi's Avatar
Default Popping Noise, need some advice..
in reguards to this post...https://honda-tech.com/zerothread?id=684687
itr707 describes my problem exactly, so im going to quote it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">been getting this popping/clicking noise latley. seems whenever i put load on the car (either step on or off the gas), i hear the pop/click noise comming from the front right wheel. only happens when starting from a standstill or whlie moving slowly and putting on load. not when standing and reving in neutral or when moving consistantly. this started happening like months ago but i would only hear the popping noise once a week or somthing. been slowly getting worse and now it's at the point where almost whenever i put load on the wheels i hear that noise comming from the front right. i don't feel anything wrong with the car, it works perfectly fine, just the noise. what could it be? bearings? axel?
stock 2000 itr 48k miles
thanks for the help!
So is it the axlel? Fat bastard said he replaced his axle and still had the same problem.
Oh this is my front drivers side wheel not the passenger, but that shouldn't make a difference.
Thanks
Old Jun 2, 2005 | 07:49 AM
Default Re: Popping Noise, need some advice.. (citrus3000psi)
After doing some searching I found a post that said the problem was the driveshaft support bearing? Do I have to go the dealership to fix this? Anybody have a part number for the bearing? Does the bearing have to be pressed? I havn't looked unde rthe car yet to see how difficult this is going to be.
Old Jun 2, 2005 | 11:51 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Help anyone...?
Old Jun 2, 2005 | 11:57 AM
p nut's Avatar
I've heard the same noise on my car everytime I'm backing out and in first gear. I'm changing out the axles this weekend, so I'll see if the noise goes away. Hopefully, that's all it is
98 with ~53k miles
Old Jun 2, 2005 | 01:14 PM
nemesis0104's Avatar
Default Re: (P Nut)
I had that noise last year and after a little while I decided to take a look at what could be causing the noise...My friend took the drivers wheel off and took the dimple out of the axel nut...He hit it twice with the air gun and it fell off inside the socket of the air gun....You could actually see a little piece of rough metal where the air gun sheered and finished it off....It was about a cm in diameter....check those axels....I got mine fixed under warranty...good luck.....
edit...wow I found the old pics...
Old Jun 2, 2005 | 04:29 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">So is it the axlel? Fat bastard said he replaced his axle and still had the same problem.
Could be motor mounts too. I know it only happens when moving, but your engine really bucks around when hitting the gas and stuff.
Can you make it happen standing still, with the e-brake on, and slipping the clutch a little? If so-- someone brave might stick their ear near your wheel/engine/etc and listen for it.
Old Jun 2, 2005 | 04:39 PM
dc2vu's Avatar
i dont have an ITR but i had the same problem in my hatchie...i started grabbing anything that could potentially be "loose" and shook the hell out of it..turned out my passenger side spindle wasnt fastened all the way at the top where it connects to the upper control arm? that A thing that the skunk 2 camber kit replaces...i just took out the cotter pin and tightened that bolt as much as i could and it went away...there was just play because the bolt was loose
Old Jun 3, 2005 | 04:40 AM
Im going to tear it down down tonight/tomorrow morning and seewe what I find.
Old Jun 3, 2005 | 05:06 AM
Wai's Avatar
Wai
From the responses above, I would look at the axle nut first and see if there's anything wrong with it. Then check the castle nut on the upper a-arm.
Hope you had that sorted out!
Old Jun 3, 2005 | 05:39 AM
DCStreetHtch's Avatar
Default Re: (Wai)
i had same symptoms/sounds with my hatch after putting in Skunk2 camber kit, check the castle nut for tightness...
Old Jun 3, 2005 | 06:23 AM
IN VTEC's Avatar
The intermediate shaft bearing has to be pressed in. I did mine last summer. I don't think it would be the actual bearing tho. I think that if it had enough play to click that loudly, it would produce a wobble/shake under acceleration as well.
Look at the carrier housing for the intermediate shaft that uses three dowel bolts to mount it to the intake side of the block. It may be loose and smacking around.
Old Jun 3, 2005 | 06:50 AM
dc2vu's Avatar
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">Im going to tear it down down tonight/tomorrow morning and seewe what I find.</TD></TR></TABLE>
best of luck to fixing your problem
Old Jun 4, 2005 | 07:26 PM
Axle nut was fine. I checked the top castle nut and it was slightly loose but not really. I tightened it and the noise is still there and still just as much. I shook the axel where the driveshaft support bearing is. It seemed loose but Im not sure if it should or shouldn;t feel loose? It didn't click or pop when I moved it. Any other Ideas? I checked the bottom castle and it was fine.
Old Jun 4, 2005 | 07:46 PM
p nut's Avatar
I tried the same (tighten axle nut, check castle nut), but the "click" is still there. Mine's also on the driver's side. It's driving me CRAZY!
Old Jun 4, 2005 | 08:51 PM
IN VTEC's Avatar
Under a centimeter of intermediate shaft play is ok, and about a centimeter or two of axle play where it mates to the intermediate shaft is ok too.
Everything sounds like it's in order with the castle nuts and int shaft.
Maybe it's a spring or shock issue.
Old Jun 5, 2005 | 08:42 PM
dc2vu's Avatar
along with that it possibly may be a busted ball joint...one of mine just screwed up while i was messin with the tie rods...just a possiblity but u might wanan check em anyways
Old Jun 5, 2005 | 08:48 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
same troubles here
Old Jun 6, 2005 | 06:29 AM
Im really suprised know one really knows what it is. Seems like a lot of people are having this issue. Next weekend I will just tear down the whole supension etc. And put it back together. Hopefully that will fix it.
Old Jun 6, 2005 | 11:31 AM
IN VTEC's Avatar
Ya know, maybe it's a swaybar endlink. I had a problem with that a long time ago with a rusted/binding endlink, but it liked to make popping noises only when I took right-hand turns.
Old Jun 6, 2005 | 11:39 AM
boy_huot's Avatar
i had the exact same problem...took it to 3 mechanics and they said ball joint, motor mount, and drive shaft...seems like drive shaft was the closest guess b/c while i was in the car he was constantly putting his body weight on the driver side front wheel then taking it off and from that you could hear the clicking sound...it drove me fuking crazy but the funny thing was it went away after a while...this was however a bit after the mechanic told me he had put lube on the drive shaft...right after he put it there was still the sound but less of it...hope this helps man
Old Jun 6, 2005 | 11:58 AM
Where did he put 'lube' on the driveshaft?
Old Jun 6, 2005 | 12:32 PM
extrah's Avatar
Crazy timing on this thread!
Last night i heard the exact same sounds, but on the front passenger side.
Earlier today I went down to my local Honda dealership, and asked one of the mechanics if he could come with me for a small ride to hear the sound. Ofcourse the sound didnt appear at that moment, but when I told him the sound only appeared when i applyed gas in 1th gear and reverse back & forward, he felt pretty sure it was my motor mounts.
I haven`t had the time to check it yet, but ill reply here if i get any smarter after its done.
Eirik.
Old Jun 6, 2005 | 01:22 PM
p nut's Avatar
Hopefully it's just the motor mounts. My axle replacement got pushed to later on toady, so I'll have updates then. Meanwhile, the clicking is getting louder by day and it's driving me CRAZY!
Old Jun 6, 2005 | 01:59 PM
RTW DC2R's Avatar
maybe I missed it, but are you guys using stock axles or aftermarket? Ive run some shitty axles in the past which always develop "play" and it tends to make a clunking noise, especially when the steering wheel is close to full lock. I put my stock axle back in and the noise is gone.
many times these clunking noises can be suspension related as well. check all tower bars, sway bars, suspension nuts and bolts for tightness or wear.
could it possibly be something in the steering system as well?
Old Jun 7, 2005 | 10:37 AM
boy_huot's Avatar
Default Re: (RTW)
citrus im not sure where he lubed it...i remember this problem had me reading alot on the local toronto forums and now i remember people telling me you can try examining the stabilizer bars and someone saying how their plastic fender liner kept getting nudged by the wheel which made the sound...hope this helps man
kenskii
Jul 8, 2014 08:33 PM
RobFarns
Oct 22, 2010 05:52 PM
ednyboo
Jun 5, 2007 08:55 PM
vi3tromanc3r
12
Nov 9, 2006 02:45 PM
typeee
Nov 21, 2003 01:05 PM
