Anyone use the HCP front mount in a b16a civic 91 setup
Old Feb 8, 2002 | 07:16 AM
91sifreak's Avatar
New User
Default Anyone use the HCP front mount in a b16a civic 91 setup
I am using the HCP mount kit and i have not fogured out how to use the front mount and i would really like it in, has anyone got that thing to fit up right. How the hell did someone change my text?
[Modified by 91sifreak, 4:21 PM 2/8/2002]
Old Feb 8, 2002 | 07:19 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: Anyone use the HCP front mount in a b16a civic 91 setup (91sifreak)
ok this is not going to make much sense because i suck at giving instructions, but in a nutshell you need to take off the crossmember from the car, get a die grinder, and basically enlarge the holes and shave a bit off the front so the crossmember mount does not hit the block.
-Todd
Old Feb 8, 2002 | 08:08 AM
daniel89civ's Avatar
do any of you have hcp mounts are they as good as hasport also are they good for turbo
Old Feb 8, 2002 | 08:26 AM
91sifreak's Avatar
New User
Default Re: Anyone use the HCP front mount in a b16a civic 91 setup (daniel89civ)
I have seen a civic b18 swap with a turbo and he is running the hcp mounts ok, he likes his, but he moved and made a new weld for the front mount. Hcp is still the only four mount set out right now too, sooooo that must mean something.....right?
shocker911
Aug 1, 2009 06:15 AM
tc_gts
Oct 5, 2006 01:37 PM
DB1_559
Jun 8, 2006 03:52 PM
0554
10
Mar 5, 2003 10:29 PM
swaplighter
Mar 2, 2003 03:21 PM
