Clutch problem/sound
If I put the car in neutral and rev the engine a bit, there is a low pitched rattle sound coming from the gearstick/gearbox area. If I push down the clutch, the sound goes away instantly. Is this the release bearing going bad??
I just had the clutch changed about 4000km ago with an Action 1KS, and the release bearing (supplied by Action) was changed along with it.
Man you've had a hell of a time lately with your car haven't you. I know with my short shifter in my gs-r it rattled all the time. My guess would be to check the linkage underneath the car and to make sure the bushings are there and intact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PY0559 »</TD></TR><TR><TD CLASS="quote">Man you've had a hell of a time lately with your car haven't you. I know with my short shifter in my gs-r it rattled all the time. My guess would be to check the linkage underneath the car and to make sure the bushings are there and intact.</TD></TR></TABLE>
Yeah... drivetrain + ITRs = bad
I checked the shift linkage during the clutch install and it was fine. I actually think it's my input shaft bearing that's going bad now:
https://honda-tech.com/zerothread?id=496467
"Bad TO bearings squeak when the clutch pedal is pressed IN and stop when the pedal is OUT (think about how your clutch works). A bad input shaft bearing squeaks when the pedal is OUT but stops as soon as any pressure is put on the pedal."
old man neri
Sep 16, 2006 05:41 PM
