hard to install speed sensor?
Old Jun 2, 2005 | 04:23 AM
freedomnf's Avatar
Default hard to install speed sensor?
I think I need to change my speed sensor. Is it hard to get to? Should I just go buy a shop manual to find out how to do it?
Old Jun 2, 2005 | 04:28 AM
EK-Chris's Avatar
Default Re: hard to install speed sensor? (freedomnf)
What makes you think your speed sensor is bad? As long as you can unbolt and unplug a connection you are fine. Follow the wires that connect to a sensor on your transmission. The will be in the area behind and below your starter. Use a 10mm socket to unbolt it, pull it up, unplug it - then plug your new speed sensor. Once the new sensor has been connected - bolt into the area you just removed it from..
Old Jun 2, 2005 | 04:33 AM
itr-00-436's Avatar
Default Re: hard to install speed sensor? (EK-Chris)
just that simple
Old Jun 2, 2005 | 04:59 AM
Ricey McRicerton's Avatar
Default Re: hard to install speed sensor? (itr-00-436)
Only word of advice is to be careful not to damage the gear on the end of the new unit you're putting in and to be careful not to snap the mounting tab off of the new unit by overtightening the bolt.
If you stand on the passenger side fender of the car and look into the engine bay it's on the back of the transmission sticking straight up with an electrical connection going to it. You seriously can't miss it.
B18C5-EH2 did a writeup on how to change transmission fluid through it, so if you need pictures, search for him as the creator, in EG+ in the archives.
Usually a dying speed sensor goes out intermittently. Sometimes it works, sometimes it doesnt, and other times the speedo just jumps around like crazy. If your speedometer just stopped working, I honestly don't think that the speed sensor is your problem.
If you want to go ahead and get a mnaula now visit http://www.helminc.com. They sell the BEST service manuals for our cars, and at $62 dollars, you'll save yourself a ton of cash in labor.
Old Jun 2, 2005 | 05:46 AM
pdiggitydogg's Avatar
^I snapped mine by overtightening
I made a new bracket with some jb weld putty. Came out fine...but I dont recommend replicating my stupidity.
Old Jun 2, 2005 | 05:48 AM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">^I snapped mine by overtightening
I made a new bracket with some jb weld putty. Came out fine...but I dont recommend replicating my stupidity.</TD></TR></TABLE>
I cracked mine. It's a LONG freaking bolt and hard to tell how tight you have it.
Old Jun 2, 2005 | 05:52 AM
Ive snapped lots of things by over-tightening
Its just dumb because it takes 30seconds to check the tq spec and do it right.
Old Jun 2, 2005 | 05:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Ive snapped lots of things by over-tightening
Its just dumb because it takes 30seconds to check the tq spec and do it right.</TD></TR></TABLE>
I've done the same thing. Threadjack in progress....
Have any of you gotten messed up readings on your torque wrenches from using a bunch of extensions? My tq wrench is WAY too big to fit down by the speed sensor, so I had to use about 2 and a half feet worth of extensions and STILL managed to damage it.
Old Jun 2, 2005 | 08:23 AM
freedomnf's Avatar
I have a 2000 civic ex. One day the check engine light came on and I didn't what the problem was. THe only thing I did before that was change the spark plugs about 5k miles earlier. I checked the wires and one of them was not pushed all the way down and that fixed the problem for about 2 weeks the the light came back on. The I installed new plugs, wires, distributor cap and rotor and it fixed the problem again but for only 2 more weeks. I've taken it to Auto Zone each time and the same code keeps coming up P1336. So from searching this site it seems that other people changed that sensor and it fixed the problem. All it seems to do is idle a little higher than normal and not run as smooth as it did before. Other than that all seems ok. Any ideas would be appreciated.
Old Jun 2, 2005 | 08:27 AM
If you really are in Raleigh (like it says) just let me know. I'll come check it out. Doesn't sound like your vss is messed up to me.
Old Jun 2, 2005 | 12:19 PM
freedomnf's Avatar
Default Re: hard to install speed sensor? (Ricey McRicerton)
Ok Thanks. Yea I'm in Raleigh. I'm off work tommorrow. I could meet you somewhere. Just let me know. If not tommorrow then maybe sometime this weekend. I appreciate it.
Old Jun 2, 2005 | 12:27 PM
Sent you an email. Probally going to have to be the weekend. I work about 60 a week.
Old Jun 3, 2005 | 01:32 PM
6elements's Avatar
noob here. thanks for the useful info
streetracerjoey210
11
Jul 24, 2016 08:02 AM
h22steaksauce
Apr 7, 2012 07:23 PM
thannon2
Jan 16, 2009 01:59 PM
custom session
Apr 27, 2007 11:52 AM
