b20vtec oil pump? b16,gsr or type r?
my friend built a b20vtec and he used a b16 oil pump.. is this a good idea or should he upgrade to a type r or gsr? cuz his vtec isnt working either. but it has 80 psi before vtec..
well we've tried 2 differeent b16 heads.. one was on a b20vtec and worked great.. and the other one he has is on the car now and does work.. tried 2 different soleniods with pressure sensors.. have a oil pressure gauge hooked up.. both soleniods clicked when saw power.. but when the car was on aand you gave them power there was no difference..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18TurboEF »</TD></TR><TR><TD CLASS="quote">my b20zvtec has a stock b20z oil pump and does great
my b20bvtec has a stock b20b oil pump and does great too
</TD></TR></TABLE>my b20bvtec has a stock b20b oil pump and does great too
Yeah this has always been an unsettled debate. IIRC, the obd2 oil pumps are all the same for b-series, they were revised flow over the obd1 and they all have the stiffer pressure release spring, but the obd1 pumps had difference between the LS/B20 pumps and the GS-R and Type R pumps. pretty sure this is correct. And yes the obd2 have the crank fluctuation sensor and the obd1 do not. You have to use the lower timing cover from the same generation OBD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">Early gsr pump does not have a mount for the crank angle sensor. Other than that, it is the same as the obd2 pump. Stay away from the b18a ls pump.</TD></TR></TABLE>
but the later LS oil pump b18b is the same as the vtec ones also right...pressure wise....????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supah_Eg6 »</TD></TR><TR><TD CLASS="quote">
but the later LS oil pump b18b is the same as the vtec ones also right...pressure wise....????</TD></TR></TABLE>Yes, obd2 LS oil pumps are the same.
DavidTurbo
Aug 7, 2007 08:19 AM
