Im converting my 92 auto to stick please help
Old Jun 1, 2005 | 01:05 PM
DualAudio's Avatar
Default Im converting my 92 auto to stick please help
what if any complications will there be when i switch my trani over cause everything is stock on the car, and help me out with a parts list, im pretty sure i know everything i need but just i case i forgot something.
Old Jun 1, 2005 | 01:09 PM
khmboostedeh2's Avatar
Default Re: Im converting my 92 auto to stick please help (DualAudio)
transmission
shift linkage
slave cylinder
clutch lines
master cylinder
clutch pedal
flywheel
clutch
Old Jun 1, 2005 | 01:12 PM
DualAudio's Avatar
Default Re: Im converting my 92 auto to stick please help (Jeterkm02)
dont you also need the resevore
Old Jun 1, 2005 | 01:55 PM
haveaniceday's Avatar
Hydraulic Reservoir... yes
Old Jun 1, 2005 | 02:02 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: Im converting my 92 auto to stick please help (haveaniceday)
You're gonna have to move the white box from the auto shifter into N to start the car. It's kind of a cool anti theft feature if you hide it somewhere....or you can just solder it to the N position. good luck, it's gonna be night and day diff in acceleration.
Old Jun 1, 2005 | 03:23 PM
SRCivic97's Avatar
Default Re: Im converting my 92 auto to stick please help (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">You're gonna have to move the white box from the auto shifter into N to start the car. It's kind of a cool anti theft feature if you hide it somewhere....or you can just solder it to the N position. good luck, it's gonna be night and day diff in acceleration.</TD></TR></TABLE>
I'm doing this conversion in about 2 weeks. I have all the parts needed. Here's your list. By the way unless what you mentioned about the white box is special to a 92...You'll need to make sure it's in [P]ark. Have you ever tried starting an automatic in [N]eutral? It wont happen, Son.
Tranny
Tranny Mounts
Clutch
Flywheel
Pressure Plate
Slave Cylinder
Master Cylinder
Hard & Soft Lines
Pedal Assembly
Shift Linkage
Flywheel Bolts
PP/Clutch Bolts
Shifter
Shift Boot
Shift ****
Old Jun 2, 2005 | 10:39 AM
Default Re: Im converting my 92 auto to stick please help (SRCivic97)
flywheel cover is differant as well. i forgot to mention that.
Old Jun 2, 2005 | 10:48 AM
evilsolb16's Avatar
you also have to get a chip takin out of your ecu. if you dont then you are going to throw a cel. i think that you have to remove rp18 and gap rp17 not 100% sure might be the other way around.(may want to search) did it on one of my single cams worked fine.
Old Jun 2, 2005 | 10:52 AM
SRCivic97's Avatar
Default Re: Im converting my 92 auto to stick please help (evilsolb16)
Or just replace the entire ECU.
Old Jun 2, 2005 | 11:25 AM
2000psi's Avatar
You are right...it has to be in park. It was a long time ago that I did this conversion now I remember that it was in Park but the P and the N will flash on the dash
f88bonilla
Aug 10, 2011 02:59 PM
jdmekB18C
Jun 4, 2004 11:30 PM
bartek_b
Acura TL, RL & ZDX
Oct 18, 2003 01:40 AM
97 teg
May 2, 2002 09:36 AM
17secondcivic
Mar 21, 2002 08:07 PM
