Need Experts on this SIR 99-00 poblem
Ok here we go
Got and SIR 99-00 motor in my 97 civic si and my freaking Vtec won't engage and also my engine does not cutoff
I have Try 3 different ECU all the same results so I know its not the ECUs cause one of them is running in my friends car and it all good in is..
So Any of your Mechanic expert out there could think of anything that could cause the Vtec not to engage or the engine not to cutoff
the tach was working with my other engine witch was Vtec also... could it be something about the wirering cause the 96-98 civic are 0bd2a and 99-00 are 0bd2b
if your missing info in this tread ask and i'll try to put more info that you need
Please Find the answer to this
I have the Harnest of the 97 civic si/ex using a OBD1 ECU with a converting harnest from obd2a to obd1
I noticed something From my Vtec selenoid I have one wire going to the distributor harness but you can see that they cut a cable in there witch is Green and hooked up the Vtec Wire to that.. could it be the wrong wire ???
hmtcrxsir
Apr 27, 2019 08:09 AM
i2ishift
Jun 4, 2009 03:38 PM
xsuperxsonx
Jul 25, 2006 08:09 AM
