radiator fan doesnt work????
Old Jun 1, 2005 | 11:26 AM
siregcivic's Avatar
Default radiator fan doesnt work????
last night i was at the gas station buying **** and left the car running while the girl was in it after waiting in line for 5 or so minutes i went and got in my car and saw that it was over halfway up the temp gauge. i started driving it and it cooled down went home shut it off.
on the way to a friends house i was sitting at a stop light and it started getting hot again so i pulled over and popped the hood and realized that the fan wasnt on, does anybody know why it would just all of a sudden it wouldnt work??
Old Jun 1, 2005 | 11:38 AM
pdiggitydogg's Avatar
does it kick on if you hardwire it to the battery?
Old Jun 1, 2005 | 11:40 AM
egryda's Avatar
Default Re: (pdiggitydogg)
your thermostat probably took a ****.
Old Jun 1, 2005 | 12:57 PM
flipsyde's Avatar
check your fan relay...
Old Jun 1, 2005 | 01:13 PM
Del Sol SiR's Avatar
it could be any of the above, including the fuse. I recently had the same probelm with an aftermarket fan, only to find out that it was the fan that was bad.
Old Jun 1, 2005 | 01:16 PM
DualAudio's Avatar
Default Re: radiator fan doesnt work???? (siregcivic)
well if its the radiator the radiator relay switch could have gone out when that geos out the car doesnt know when to turn the fan on and if its not your radiator that casues your car to over heat it could be your water pump.
Old Jun 1, 2005 | 06:43 PM
siregcivic's Avatar
Default Re: radiator fan doesnt work???? (DualAudio)
wow my car is freaking wierd. after yeasterday it overheating it works today......i dont know just all of a sudden was working today so its fixed.
Old Jun 1, 2005 | 09:45 PM
egryda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">wow my car is freaking wierd. after yeasterday it overheating it works today......i dont know just all of a sudden was working today so its fixed.</TD></TR></TABLE> i wouldnt say its fixed. its going to happen again.
Old Jun 2, 2005 | 12:47 AM
VicThaDish's Avatar
New User
That pretty much sounds like your thermostat is starting to go bad. You may want to change it because it will happen again
darin108
Aug 8, 2014 05:46 AM
JH4DB858
Jan 10, 2012 07:32 PM
G. Man
Classic Hondas
13
Sep 2, 2011 10:36 AM
Monotremata
May 18, 2011 05:21 PM
Mag00n
Jul 31, 2003 05:12 AM
