Suspension & Brakes Theory, alignment, spring rates....
need swaybar options for EJ6
Old Jun 1, 2005 | 10:46 AM
d16rice's Avatar
Default need swaybar options for EJ6
I have a 1997 civic hatchback
My current suspension setup is:
Gas struts
lowering springs
aftermarket RL control arms
'00 Si front upper tie bar
Generic rear lower tie bar.
Does any one make a front sway-bar for 96-00 civic CX/DX?
I heard somewhere that there are kits that would not require me to change my front control arms, but I have never seen them myself.
Old Jun 2, 2005 | 04:45 AM
d16rice's Avatar
Default Re: need swaybar options for EJ6 (d16rice)
bump
Old Jun 4, 2005 | 05:38 AM
BLUE EH3's Avatar
Help we my pennies
With the new wheels and tires, the extra grip caused a ton of body roll, so I decided to speed things up and install sway bars both up front and in the rear.
Due to the easy availability from an friend, I decided on the Suspension Techniques sway bar kits. Out of the box, these kits came with polyurethane bushings and functional installation instructions.
Rear Sway Bar
Installation of the rear sway bar was pretty easy, although some minor drilling was reqired for mounting the sway bar pivot points. The two pivot points mount on the rear lower cross member of the chassis. One extra hole had to be drilled so that the brackets could be bolted on, and this proved to be reasonably easy.
For the ease of future adjustment/reinstallation, I opted to thread the mounting bolts outwards from within the cross member. This also gives the suspension's lower arm more clearance at the inboard pivot point.
The kits also came with adapter bracket mounting points that connected to the lower end of the shock absorbers. We found the instructions to be off here in that the end of the shock must be turned 180 degrees so that the adapter bracket will be in the right position.
Finally the bar had to be manoeuvered into place as it actually snakes in and out of the suspension components. Then everything was bolted down and checked that everything was clear through the entire suspension travel. Still, I wonder what will happen if I try to get a lower strut bar in there.
Front Sway Bar
The front sway bar was a little more complicated than the rear. As my car did not have any sway bars, the suspension arms did not have the mounting holes. Hence the supplied brackets had to be used.
The first step was to get the adapter brackets mounted. This did not prove to be too difficult and everything bolted on correctly.
Next two subframe bolts had to be removed and the supplied pivot points were put in. The design seemed strange but it seemed very strong so we decided to take a wait and see attitude.
Bolting the main bar up, I found the clearance between the catalytic converter to the bar to be insufficient, so I went ahead and removed the heat shield, which gave it a little more clearance (about 1.5cm). The rest of the bar went in fine and again I double checked everything.
The Test Ride
Taking the car out for a test drive, I found the handling very much improved. Even with the front bar, the feel is very neutral, although the car seemed to understeer more on lefts than rights.
I took it back and double checked everything. Everything seemed fine. I turned my attention to the brakes and true enough, one of the pads on the right rear brake wasn't sitting properly (probably a minor oversight during the brake install). Fixed it and took it out for a spin.
With that minor glitch ironed out, the car handles beautifully. No more understeer sideways wheel-hopping. In fact it's easy to push the car into slight oversteer. Got to take it to the track soon to push it to its limits.
HustonB
13
Jan 3, 2013 11:36 AM
207prelude
Oct 12, 2009 03:40 PM
OR-G
13
Jul 30, 2004 12:23 AM
Blue-Civic-Hybrid
Jan 21, 2003 05:13 PM
mr2td
Oct 14, 2002 06:00 PM
