proper position for intake
i got a k&n intake from ebay about 3 months ago. the pipe barely fit and the filter barely even got in there. it is touching the coolant resvoir. should it be that close? basically bottom line....should i buy a new intake that fits better...
you get what you pay for suckaaa..lol jp
if you want help put some more detail. what car?
possible to take a pic?? yes ive seen filter close to coolant resvoir. but not touching. try to push filter into pipe more
99 LS. its probably ok but it just seems like the filter shouldn't be so close to the anit-freeze resevoir. i would post a pic but i dont know how to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 »</TD></TR><TR><TD CLASS="quote">no its not bolted down...but its so tight in there it has virtually no movement anyway. it didnt come with anything to stabilize it really.</TD></TR></TABLE>
THere's a spot to throw in a bolt from where you took your stock airbox out. See if you can drop a 1" bolt in there and then use a zip tie to secure the CAI to the bolt so it doesn't hit your coolant or AC lines.
mitcho
13
Jul 12, 2007 05:39 PM
Manolo
55
Jul 13, 2005 07:26 AM
Nihilus
11
Mar 10, 2005 04:31 PM
ef_you
10
Jan 11, 2005 12:24 PM
