Idle surge when switching between ECU's
Old Jun 1, 2005 | 09:29 AM
dunkd's Avatar
Default Idle surge when switching between ECU's
obd1 del sol with b16
chipped p28 everything runs great no problems.... then when the usdm p30 is installed the idle surges from 1000-1400 when the car becomes warmed up.
swap ecu's and the problem goes away, the only thing different between the ecu's is the knock sensor which is wired up correctly. No CEL's.
does the probem lie within the p30? or is there something i am overlooking between the ecu's?
Modified by dunkd at 1:58 PM 6/1/2005
Old Jun 1, 2005 | 07:23 PM
dunkd's Avatar
ttt
Old Jun 3, 2005 | 09:14 PM
amy's Avatar
amy
Default Re: (dunkd)
hmm i would like to know as well
Old Jun 3, 2005 | 09:35 PM
Jim Truett's Avatar
Default Re: Idle surge when switching between ECU's (dunkd)
I would assume the P28 has a chip that disables closed loop operation. When the stock P30 is installed, the idle mixture is off (too lean) and causes the surging.
Old Jun 3, 2005 | 09:39 PM
dunkd's Avatar
Default Re: Idle surge when switching between ECU's (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">I would assume the P28 has a chip that disables closed loop operation. When the stock P30 is installed, the idle mixture is off (too lean) and causes the surging.</TD></TR></TABLE>
uhh, car is running in open loop with stock o2 sensor. the p30 is the right ecu for the motor and car...
Old Jun 3, 2005 | 09:40 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
uhh, car is running in open loop with stock o2 sensor. the p30 is the right ecu for the motor and car...</TD></TR></TABLE>
Closed loop operation is with O2 sensor feedback. Open loop is direct from the maps.
Old Jun 3, 2005 | 09:45 PM
dunkd's Avatar
hmm ok, well can u explain why a p30 would cause this motor to run lean? being as that its the right ecu...
Old Jun 3, 2005 | 09:47 PM
Jim Truett's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">hmm ok, well can u explain why a p30 would cause this motor to run lean? being as that its the right ecu...</TD></TR></TABLE>
Try adjusting the idle mixture bleed screw on the throttle body, or jump the service check connector and set the baseline idle with the IACV disconnected.
http://www.pgmfi.org/twiki/bin...gMaps
john159753
Apr 26, 2013 10:35 AM
97ek9
Jun 22, 2007 07:09 PM
SkoundrelUSA
29
Nov 10, 2005 06:28 PM
vtecmike1
18
Feb 13, 2005 01:57 PM
Chris N
Dec 4, 2003 09:40 AM
