vtec problem
Old Jun 1, 2005 | 09:04 AM
vtecRDS's Avatar
Default vtec problem
hello everyone im new here have a little problem i have a b16a and it does not activate VTEC the ECU is throwing code 22 i read in the sticky above that it was the Vtec pressure valve, problem is i dont know where the is locatedor how to fix it.. also on another list of codes code 22 is VTEC oil pressure switch if anyone know how to fix this issue please post it up..
thanks in advance
Old Jun 1, 2005 | 09:12 AM
WildPig's Avatar
Default Re: vtec problem (vtecRDS)
The vtec pressure switch is the sensor with the little green plug on your vtec solenoid........ if you don't know where that is, it's on the back passenger side of your head. I'll try and find a pic........
Old Jun 1, 2005 | 09:14 AM
WildPig's Avatar
Default Re: vtec problem (WildPig)
^^^^ and there it is, green plug.
Old Jun 1, 2005 | 09:43 AM
vtecRDS's Avatar
ok so i replace the sensor and that should cure my problem?
Old Jun 1, 2005 | 09:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Lol whose car is that? Thats some ghetto *** wiring.
Old Jun 1, 2005 | 03:26 PM
vtecRDS's Avatar
bump
Old Jun 1, 2005 | 03:30 PM
92eg6's Avatar
did u replace it? did u just get the swap done? cause i had the same problem but it was the wiring, double check the wiring, ur probably also redlineing maddddd early like at 6700
Old Jun 1, 2005 | 06:27 PM
vtecRDS's Avatar
Default Re: vtec problem (92eg6)
exactly im redlining early about 6800 and the swap was done bout a year ago, can i test the vtec using a switch to run power to the pressure switch and the selenoid will it activate that way?? im going to doble check the wiring too.. how do u replace the sensor i have no idea how u pull it out..
Old Jun 1, 2005 | 07:03 PM
92eg6's Avatar
yup u see, guessin ur obd2? well the pressure switch is very easy to take off, from wat i remember its a sz 22mm wrench...i thnk not 100% sure, but u jus unplug the green switch and stick the wrench in there and turn, and it comes out.....damn u did the swap a year ago and no vtec and redlineing at 6700?!? u must get spanked by sohc vtecs all day lol i went like all summer w/o vtec and wen u first feel it ur llike double check the two wires goin to the pressure switch ones blk n blue n ones blk i think
Old Jun 3, 2005 | 11:09 AM
vtecRDS's Avatar
ok i figured the wiring was loose theres 4 wires a blue, green, black, red what exactly do i need so that vtec engages??? the selenoid and the pressure swith or is there other stuff??? the car aint mine and the guys who did the swap did some ghetto wiring im trying to figure out how to get vtec to engage..
Old Jun 4, 2005 | 11:44 AM
vtecRDS's Avatar
bump
Old Jun 4, 2005 | 11:56 AM
eg8000rpm's Avatar
Dude I think you might have something else wrong for VTEC not to engage
I throw the same code (22) after I swapped but engine runs fine and VTEC engages.
I have had it checked out by the local honda expert mechanic around here and he cannot find anything wrong with my pressure switch I got to the point where I just mounted my VAFC where I cannot see that annoying little orange light pop on
I would like to know the outcome of this problem though.
Bump ttt
Old Jun 6, 2005 | 01:46 PM
92eg6's Avatar
Default Re: vtec problem (eg8000rpm)
u sure ur engageing vtec, does it say vti:ON wen u go into vtec on ur vafc? cause every1 i knew including me didnt engage in vtec, cause thats a pretty common cel w/swaps
Old Jun 6, 2005 | 01:53 PM
IHateJDM's Avatar
vtec is 3 wires. One wire for the solenoid (goes to A4 pinout), 2 wires for pressure switch (Positive wire goes to D6, negative goes to A26 on some ecu's, but on P28 the negative can just be grounded to the head). Trace your wires before you start spending money on sensors.
HondacivDX
Feb 19, 2012 03:25 AM
TristanW10
Mar 15, 2010 03:33 PM
IlIkEg's
Nov 15, 2005 11:22 PM
punkassazn
Oct 1, 2004 12:13 PM
