a/c question (its getting hot in cali)
Old Jun 1, 2005 | 12:42 AM
slowpokecivic's Avatar
Default a/c question (its getting hot in cali)
i tried searching but ac was too short or very little things come up when i typed it out...i was wondering if an ac system from car A willl fit into car B...
Old Jun 1, 2005 | 01:25 AM
oreozzz's Avatar
Default Re: a/c question (SLoWpOkECiViC)
whats car "A" and whats car "B"
try to be just a tad bit more specific
not trying to be sarcastic either just need more information to get an exact answer
Old Jun 1, 2005 | 06:38 AM
civic-si-2000's Avatar
Default Re: a/c question (oreozzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oreozzz &raquo;</TD></TR><TR><TD CLASS="quote">whats car "A" and whats car "B"
not trying to be sarcastic either just need more information to get an exact answer </TD></TR></TABLE>
Post it up and I can help I'm pretty good with a/c systems.
Old Jun 1, 2005 | 06:59 AM
tonis56's Avatar
Default Re: a/c question (civic-si-2000)
It completely depends on what refrigerant car A used versus car B's refrigerant.
Old Jun 1, 2005 | 07:33 AM
integraXTC's Avatar
hey don't mean to jack the thread, but I have a similar question and this dude isn't being more specific.
How about I get the entire ac system off a 95 vic and try to put it on a 92. What will I have to do, just plug and play? retrofit? how hard will all this be (i'm a noob, but still think I can do it)
Old Jun 1, 2005 | 07:38 AM
tonis56's Avatar
Default Re: (integraXTC)
Im guessing that it would be a direct replacement. I believe that both systems are R12 refrigerant. I would reccomend that this would be done by a professional that has the tools and the knowledge to do this.
Tony
Old Jun 1, 2005 | 08:31 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXTC &raquo;</TD></TR><TR><TD CLASS="quote">hey don't mean to jack the thread, but I have a similar question and this dude isn't being more specific.
How about I get the entire ac system off a 95 vic and try to put it on a 92. What will I have to do, just plug and play? retrofit? how hard will all this be (i'm a noob, but still think I can do it)</TD></TR></TABLE>
if you have everything off the 95, you should be good to go. 94+ use R134a. the only important differences are the seals on the lines. R134a will eat through the seals on a R12 system
Old Jun 1, 2005 | 08:56 AM
cheehee's Avatar
Default Re: (dantastic)
will the a/c from a 99 GSR fit in a 00 Civic if I'm doing the engine swap as well?
Old Jun 1, 2005 | 09:05 AM
integraXTC's Avatar
cool, thanks. I don't think the tools will be a problem. Plus I'll only take it to a professional to have it recharged.
Old Jun 1, 2005 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXTC &raquo;</TD></TR><TR><TD CLASS="quote">cool, thanks. I don't think the tools will be a problem. Plus I'll only take it to a professional to have it recharged.</TD></TR></TABLE>
You can buy a recharge kit from Napa. just look at the specs for yourcar and fill it accordingly. You don't need a professional to fill the system only to drain.
Nowadays most retrofit kits are compatable with older systems so you dont have to change the seals.
Old Jun 1, 2005 | 11:02 AM
Ignitecivic's Avatar
Default Re: (civic-si-2000)
i got a 92-95 civic almost complete A/C system for sale.it came out of my 93 civic hatch. just no evap(black box) inside the car, everything else is there.
https://honda-tech.com/zerothread?id=1251715
Old Jun 1, 2005 | 12:12 PM
1320EF's Avatar
Default Re: (Ignitecivic)
a/c just roll down the windows.
Old Jun 1, 2005 | 12:34 PM
redcivic777's Avatar
Default Re: (1320EF)
that doesn;t work in Az where it's 100+++++
Old Jun 1, 2005 | 01:55 PM
integraXTC's Avatar
or in Illinois where it gets 82-92 consistantly in the summer.
Old Jun 2, 2005 | 10:26 AM
1320EF's Avatar
you must drive faster!!!!!!!!!!!!!!!!! to get the full effect.
Old Jun 2, 2005 | 12:19 PM
fast2camciv's Avatar
ok so what about the a/c out of a 94 del sol into a 93 4dr civic? do you think the lines and everything are the same?? my 4dr used to have air and the old owner tore it out, now i want it back in and have access to all the a/c parts from a del slo.
Old Jun 2, 2005 | 01:50 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
if you have everything off the 95, you should be good to go. 94+ use R134a. the only important differences are the seals on the lines. R134a will eat through the seals on a R12 system</TD></TR></TABLE>
The seals are different and so is the refrigerant oil used with 134a. Its also important to note that 134a requires higher pressures over r12.. In this case, a conversion should not cause any issues. I had mine converted before I pulled it out and it seemed to work just dandy. 134a doesn't "eat" seals on r12 systems either.
Old Jun 6, 2005 | 01:59 AM
Default Re: (Hybrid93Eg)
sorry for the dissappearance got caught up with work....i have a 96 civic....and was wondering if an a/c system from a different civic like 92-95 or a 94-01 integra would fit...
E36 Guy
14
Aug 4, 2006 10:44 AM
turboman
23
May 8, 2005 11:20 AM
revolt_allmotor
Dec 15, 2004 10:38 PM
D16OnTop
Dec 1, 2003 02:36 PM
