How much gas does a 4th gen's tank hold?
4th Gen Type S
Engine
· Type: In line-4, aluminum block
· Displacement: 2156cc
· Compression ratio: 8.8:1
· Valve Train: SOHC, 4 valves per cylinder
· Power (SAE net): 135bhp/101 kw @ 5200rpm
· Torque: 142lb-ft @ 4000rpm
· Acceleration 0-100kms (0-60mph): 9.2 secs
DriveTrain
· Transmission: 5 speed manual or 4 speed automatic
· Final drive ratio: 4.06 (manual), 4.29 (automatic)
Dimensions
· Wheelbase: 100.4 in
· Track: 60.0 in (front), 59.6 in (rear)
· Length: 174.8 in
· Width: 69.5 in
· Height: 50.8 in
· Curb weight: 1275 kgs/2809 lbs (5sp manual), 1299 kgs/2862 lbs (4sp auto)
· Fuel capacity: 15.9 US gallons
Suspension
· Front: ind, unequal-length control arms, coil springs, anti-roll bar (25.4mm)
· Rear: ind, unequal-length control arms, coil springs, anti-roll bar (23.0mm)
· Type: rack-and-pinion, variable power assisted
· Turns, lock-to-lock: 2.9
· Turning circle, curb-to-curb: 35.9 ft
Brakes
· Type: 4-wheel disc, power assisted
Wheels & Tyres
· Wheels: 14 in steel
· Tires: 185/70 HR14
Engine
DriveTrain
Dimensions
· Length: 174.8 in
· Width: 69.5 in
· Height: 50.8 in
Suspension
Brakes
Wheels & Tyres
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH »</TD></TR><TR><TD CLASS="quote">1993 Honda Prelude S: Fuel Capacity 15.9 gallons.
Lewdin' Incognito do you mind telling us where you got that info from?
</TD></TR></TABLE>no problem...
I've found a couple different places with the specs on it, but I got this specific one from http://cjnicolas.tripod.com/
It has S, Si, VtiR for the 4th gen and a chart showing specs for 5th gen base and vtec.
I'm not familiar with the tanks themselves, but sounds like whatever sensor is in there is not in the right place.
-I'm not sure if this is even possible - that's one thing I haven't had apart, maybe someone can follow up on this?
in my 3rd gen, it was not uncommon for the light to come on with 4+ gallons...
just know what your mileage is generally like, you'll be fine
I had a 93 S and there would be easily 2, usually 3 gallons when the light came on. Then the light would sort of fade in and out. Guages aren't all that accurate.
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker »</TD></TR><TR><TD CLASS="quote">15.9, but I've squeezed just under 17 gallons in before the fuel was about to spill out. </TD></TR></TABLE>
Cleanup, Pump 3. Cleanup on pump 3 please.
hm... one time i ran the gas til it dry... well according to the gauge at least... no bars of gas left... than when i pumped it came out to be about... 15.1 gallons...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin Incognito »</TD></TR><TR><TD CLASS="quote">
Slow and easy, you can't rush it.
</TD></TR></TABLE>Slow and easy, you can't rush it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dongoesby »</TD></TR><TR><TD CLASS="quote">but it is weird for my S 4th gen lude. When my fuel light was on, 10 gallon will make my tank full... hmmm... 5 extra gallons reserved?</TD></TR></TABLE>
yeah, thats how it is on my si. i like it though, i know that if my car gets down to empty, i still have almost 6 gallons left.
99Interlude
Jan 11, 2002 09:18 AM
