z6head/y8 block combo...which timing belt?
Old May 31, 2005 | 07:29 PM
SOHC_MShue's Avatar
Default z6head/y8 block combo...which timing belt?
I am going to be swapping out my y8 head this week for a better flowing z6 head. Any idea what timing belt would work best? We did this in the past on a friend's car, but i can't remember if the y8 belt we used was tight enough or not.
Old May 31, 2005 | 07:36 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: z6head/y8 block combo...which timing belt? (SOHC_MShue)
I was asking this earlier... was trying to just use my z6 head since it was complete over the y8 head but to my understanding the teeth on y8 cam gear are the same. So wouldn't it not make a difference which was used?
Old May 31, 2005 | 07:37 PM
93civicEX's Avatar
to my knowledge, you use the belt that came off the head so, z6 head swap, z6 timing belt, But i could be wrong
Old May 31, 2005 | 08:03 PM
murmur9's Avatar
Default Re: (93civicEX)
Use the same timing belt for the same head and it should match up. the teeth are pretty much the same. well they are
Old May 31, 2005 | 08:22 PM
SOHC_MShue's Avatar
well the z6 and y8 cam gears have the same amount of teeth so it has to do with something else.
Old May 31, 2005 | 10:21 PM
SOHC_MShue's Avatar
bump. Anybody with personal experience?
Old May 31, 2005 | 10:47 PM
Status Sean's Avatar
whatever head = same belt !
Old May 31, 2005 | 10:52 PM
SOHC_MShue's Avatar
Default Re: z6head/y8 block combo...which timing belt? (rw92civic)
dayum i don't have a z6 belt. Actually my friend may have one with the head. I hope so.
Old May 31, 2005 | 11:39 PM
Calvinator's Avatar
Yeah, I used a z6 timing belt on my old y8 block/z6 head combo.
Old Jun 1, 2005 | 12:01 AM
INVALID's Avatar
SOHC, what headbolts are you going to use for this? I've actually heard of a few issues between the mix and match and was interested to hear which you're going to use.
Old Jun 1, 2005 | 06:51 AM
SOHC_MShue's Avatar
Default Re: z6head/y8 block combo...which timing belt? (INVALID)
I have y8 arp headstuds. Should I get something else?
Old Jun 1, 2005 | 08:50 AM
SOHC_MShue's Avatar
bump. Need headstud info!
Old Jun 1, 2005 | 09:37 PM
Calvinator's Avatar
Damn I wish I could remember..I used a mix of both. Either 1 z6 and the rest y8 or the other way around. Anyways, PM Br1anpham, and he will tell you what he ordered from arp, it was custom for z6/y8 hybrids.
Old Jun 3, 2005 | 05:36 PM
SOHC_MShue's Avatar
Default Re: z6head/y8 block combo...which timing belt? (xtremeazian)
check it out guys. My new z6 head ready to go on
Old Jun 3, 2005 | 06:11 PM
Ol'SkoolDA9's Avatar
clean clean!!! hope it does well
Old Jun 3, 2005 | 06:18 PM
SOHC_MShue's Avatar
Default Re: z6head/y8 block combo...which timing belt? (Ol'SkoolDA9)
dohc4life
Aug 14, 2010 08:50 AM
blinger
Jul 22, 2007 04:33 PM
buddy4002
Nov 10, 2006 12:54 PM
mike93eh
Jul 20, 2005 04:23 PM
DA91TEGGY
Apr 19, 2005 03:55 PM
