wiring vtec
Old May 31, 2005 | 07:10 PM
kazaa187's Avatar
Default wiring vtec
ya i am tryin to wire vtec in my car an i called a honda dealer shiip an they told me that i can take out 3 wires that go into my ecu an use those pins but he wouldnt tell me which ones or which pins i would use for the vtec
Old May 31, 2005 | 09:14 PM
93Civac's Avatar
Default Re: wiring vtec (kazaa187)
I dont know how to do it but we will need more info before someone can answer your question.
1. What year make and model car
2. What computer
Old May 31, 2005 | 09:31 PM
94hatchling's Avatar
try this.... https://honda-tech.com/zerothread?id=1171263 its like the 3rd post down. and youmight need those codes if youi end up throwing one if something isnt hooked up properly. just do a search first bro. you'll find a lot i swear. at least look around. if you have any questions just catch me on PM or IM me at tcs64hxc. good luck.
Old Jun 1, 2005 | 02:51 PM
Default Re: wiring vtec (tcs64i6)
oh and as for the pins..... go to your local pick and pull, and grab a ecu harness plug. make sure to cut with enough wire to solder to. that way you have a clean install. you can either take it apart like it says in the above link, or do it the easy way and tap it with a hammer (the old plug that is) take the 3 pins and solder to your wire running to the engine bay.
best of luck.
jdmlude_dude
Dec 13, 2009 07:54 PM
trickster kid
10
Aug 30, 2009 08:02 PM
vtec25
Jul 14, 2005 10:33 AM
NorcalHB94
Apr 16, 2005 02:37 PM
