93 SI failed smog need help figuring out why
Old May 31, 2005 | 06:45 PM
DC4_MADMAN's Avatar
Default 93 SI failed smog need help figuring out why
My friends SI failed smog and the only thing that failed the visual\check was his timing, it was at 8 BTDC.
He failed the roller test BADLY.
I have never tried diagnosing a failed smog as I have always passed, but is there anything in the numbers that can help me determine what the problem is?
Old May 31, 2005 | 06:47 PM
TenLarge's Avatar
Default Re: 93 SI failed smog need help figuring out why (4door_demon)
i cant help you but others can....maybe a scan of the results or a pic of the paper or w/e will help but for now,
bump
Old May 31, 2005 | 06:53 PM
93_hatch's Avatar
Default Re: 93 SI failed smog need help figuring out why (TenLarge)
fix the timing and get it smoged
Old May 31, 2005 | 06:54 PM
DC4_MADMAN's Avatar
Default Re: 93 SI failed smog need help figuring out why (93_hatch)
You think thats the only prob? Hes already failed twice.
Old May 31, 2005 | 11:12 PM
Jedi_Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">You think thats the only prob? Hes already failed twice.</TD></TR></TABLE>
YES! timing affects smog a lot. I can vouch for this. my timing was at 19 and smoke was coming out of my exhuast during the test. obviously i failed.
lowered the timing to 15 and i passed the emissions part, not much, but still passed.
fix the timing to where it should be (i believe it should be 14-18), this is where the engine will be at its most efficient, then he should pass no problem.
James
mish__
10
Oct 5, 2011 06:09 AM
Green Deli
Sep 16, 2009 06:17 PM
951dc5
Dec 17, 2006 09:39 AM
vile10
13
Nov 8, 2004 09:17 PM
