can i make 190whp?
Old May 31, 2005 | 04:05 PM
FormulaGSR's Avatar
Default can i make 190whp?
okay heres the deal. I'm collecting parts to rebuild my daily drivers motor. Its a 95gsr. I'm trying to make between 190-200whp on motor and then spray on top. The internalls will be forged but i'm really trying not to have to spend the extra cash on a sleeved block. So far i have a typeR head with toda springs, cam gears and portflow retainers. Cams are gsr but i plan on changing them obviously. i have victor x manifold, three inch thermal exhaust and a dual friction clutch masters. I'm planning on using a ls block with a final compression of about 11.0-1. i dont know if i'm going to have to get a sleeved block and bore to 84 to make my power goals, or what king of cams i'm looking at using. I really want to keep the powerband under 9grand since this is a daily driven car. any suggestions would help a lot.
Old May 31, 2005 | 04:28 PM
Professor15's Avatar
Since you want to keep the Rev's under 9K Buddyclub 3+ make power under those rpms. And porting along with a good header and tunning will get you past the 200whp barrier. But you shouldnt worry about peak horsepower, having a nice powerband is more important.
Old May 31, 2005 | 04:30 PM
FormulaGSR's Avatar
Default Re: (drchulo)
iif thats the case should i sell this head and buy one thats already ported? Ir really hate to have a typr r head ported.
Old May 31, 2005 | 04:45 PM
Default Re: (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">iif thats the case should i sell this head and buy one thats already ported? Ir really hate to have a typr r head ported.</TD></TR></TABLE> Why would you hate to have a type R head ported? i would send it to a respectable head porter and have them do it correctly instead of buyin it from someone else.
Old Jun 1, 2005 | 04:30 AM
FormulaGSR's Avatar
i didnt want to port the head cause its kinda a high dollar item. I figure it would be better to leave it alone or sell it to get a ported b16 head. I think i spent about 1300 on this head already.
Old Jun 1, 2005 | 05:03 AM
Grand's Avatar
id sell the r head and buy a b6 head and have it ported
itr heads are way overpriced imo for the price of one you can have a b16 head that will own it
Old Jun 1, 2005 | 06:01 AM
js96ek's Avatar
I would sell the head and get a gsr/b16 and have it ported.
Old Jun 1, 2005 | 06:16 AM
97L-esVeeTeg's Avatar
Default Re: (js96ek)
honestly you could probably keep the head, and get a good header and probably some skunk 2's and decent tuning and see a peak number of 190 or so.
A simple set-up will net some decent gains, a ITR TB and IM, good valve job, header and properly matched cams, along with parts you already have and MOST importantly a good tune can easily produce a "strong" motor something that has a healthy powerband along with a good peak number for bragging rights.
Old Jun 1, 2005 | 07:03 AM
FormulaGSR's Avatar
Default Re: (97L-esVeeTeg)
^ thats kinda wha ti was thinking. I figured te head would be good for the power i'm trying to put down. Most of this motors power will come in a bottle. I just need something that will be relatively healthy on the street.
hows the victor x manifold compare to the typeR? I'm thinking i may need to sell it for something with longer runners and a smaller plenum to keep the power band under 8500-9 grand.
Old Jun 1, 2005 | 07:15 AM
Micro's Avatar
just make sure your compression is good... get some good cams (Rocket, buddyClub, Skunk2... all proven) some head work, and definitely a good header, and your 1.8 should make high 190's easily.
if you want to sleeve it to 84mm... generally, with all the above work mentioned, plus 84 mm, you should get around 220hp average
chaokongz
Jul 4, 2009 01:06 PM
mattcivic
15
Feb 21, 2006 09:43 PM
lemongreenhatch
10
Oct 21, 2004 03:24 PM
swaytec360
15
Oct 17, 2004 04:09 PM
RTW DC2R
Apr 2, 2004 08:02 AM
