97 spec itr cams vs ctr cams worth the savings in my lsvtec ?
Old May 31, 2005 | 03:27 PM
omgwtfhaxnub's Avatar
Default 97 spec itr cams vs ctr cams worth the savings in my lsvtec ?
i found some 97 itr cams with aem cam gears for about $320 shipped i was wondering if this would work ok or should i just save up for some ctr cams will the extra duration really make that much of a difference
mildly ported b16 head
.5mm oversized valves
jg throttle body
port matched skunk 2 manifold
dc 4-1 header
11ish compression ratio
Old May 31, 2005 | 05:18 PM
Dougie Pants's Avatar
Default Re: 97 spec itr cams vs ctr cams worth the savings in my lsvtec ? (omgwtfhaxnub)
the only differense between the '96-'97 Spec ITR cams and the CTR cams is 3 degrees of duration on the Intake vtec lobe. I know this because I had a '96 Spec JDM ITR and we measured the difference between the CTR my buddy put in his B16. I made 191whp on the OEM P73 ecu
Old May 31, 2005 | 06:42 PM
Default Re: 97 spec itr cams vs ctr cams worth the savings in my lsvtec ? (Dougie Pants)
i was just wondering if that 3 degrees of duration would make that much of a difference
Old May 31, 2005 | 07:38 PM
maybe 1 oe 2 hp to the flywheel. So no.....
Old Jun 1, 2005 | 01:58 PM
thanks for the info
Old Jun 1, 2005 | 02:32 PM
np
rico suave
May 27, 2012 09:32 PM
smkngsr
16
May 15, 2005 10:49 AM
dornon13
Jul 17, 2004 11:48 AM
498GSR
Oct 28, 2002 10:06 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
