Need best brake bleeding instructions?
Brake pedal too low to floor after last brake change to pass state inspection. Can anyone give good bleeding instructions, or pedal height adjustment info? Thanks!
grab a friend or somebody to come and sit there, jack up and support car on stands, locate bleeder (some still have rubber cover on it, some dont), i believe it is an 8 mm wrench you will need, have person pump brakes up and then hold slight pressure on the pedal as it will move down when bleeder is turned,
turn slightly until some fluid comes out and tightened again before they let pressure off pedal. do that to any/all brakes you changed to be sure and then check pedal to see if it is back.
did you do the rears?? if so, did you adjust them after putting new ones on??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buy my boosted ek »</TD></TR><TR><TD CLASS="quote">you're suppose to do it in a sequence. like this...
2 4
3 1</TD></TR></TABLE>
hmm im pretty sure its always the farthest caliper in order..
for example i do mine in this order.. 4 3
2 1
back right, back left, then front right and finally front left.. repeat over and over and over till pedal gets more firm...
2 4
2 1
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nextelbuddy »</TD></TR><TR><TD CLASS="quote">
2 1
back right, back left, then front right and finally front left.. repeat over and over and over till pedal gets more firm...</TD></TR></TABLE>
Ya i did it this way, its really good, got all the air out of my lines after i did the prop valve swap.
2 1
2 4
THIS is the correct order, the other order listed above is NOT correct. Will it work? Sure, it CAN, but its not the correct way to bleed the system. Also, its important to note that when you "pump" the pedal a few times, to do it SLOWLY. Pumping the pedal like a mad man (like most people do) will simply break up the air bubles from large ones into very tiny bubbles and makes it that much harder to get the air out. Don't forget to also check the master cylinder level frequently to avoid running it dry. That would not be a good idea.
2 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barkwaffle »</TD></TR><TR><TD CLASS="quote">Did not do the rear drums yet..... would that help? and thanks!</TD></TR></TABLE>
You need to do all the brakes and you need to do it in the correct sequence listed above.
ricehater60453
Honda Civic (2001 - 2005)
Jul 12, 2010 11:25 AM
CivicHP
Sep 30, 2005 01:32 PM
