Integra Upper control arm.
I need the joint thats on the outside of the uppercontrol arm anyone have a part number for it? Does it come seperate from the whole arm?
http://www.acuraoemparts.com/d...ch=no
THANX Edo
THANX Edo
You talkin about #9, #20, and the part around it? If so you can find plenty of them used because people put in Ingalls camber kits that replace those parts.
I got a set you can have - just the arm and balljoint (no fasteners, shock tower mounting brackets, or bushings). You just need to replace the balljoint boot since I gashed them using a fork to split the balljoint off the knuckle.
If you don't want to replace the boots, I can do it for you since I might have a spare pair of upper balljoint boots in the spare parts box. You'd have to pay me for a replacement set tho since I might have need for them later on.
PM me if you want them.
whyS0serious
Suspension & Brakes
Apr 17, 2018 12:45 PM
