What probs. with oversized injectors?
Old Feb 7, 2002 | 06:00 PM
blazin's Avatar
Default What probs. with oversized injectors?
What are the negative things associated with getting say 310 injectors for a N/A ITR? Which type of injector do the ITR's require;Saturated?
Old Feb 7, 2002 | 09:50 PM
t's Avatar
t
Default Re: What probs. with oversized injectors? (blazin)
Getting them to idle and the fuel smell at cold startup/idle
you would get the saturated injectors
Old Feb 12, 2002 | 04:50 AM
blazin's Avatar
Default Re: What probs. with oversized injectors? (t)
Do they cause the car to idle funny and can that be fixed with Vafc?
Old Feb 12, 2002 | 05:18 AM
Mike K's Avatar
You can make them idle better by reducing fuel pressure or by using the V-AFC.
I've run 310s on a 1.8 before, same with two of my friends. No real problems. Sometimes the car runs rich on the low end, but that's it.
Now 370s are a different story. LOL.
Old Feb 12, 2002 | 10:40 AM
Austin's Avatar
Default Re: What probs. with oversized injectors? (Mike K)
I'm partial to the 440's...they work like a charm...but then again my ecu is programmed for them...
civickiller
May 12, 2010 02:10 PM
racinskittle
Jan 18, 2004 07:06 PM
sushibug
May 5, 2002 11:09 PM
CKim
Jan 15, 2002 06:29 AM
SpeedMonkeyRacing
Oct 4, 2001 07:28 AM
