headgasket on a 99 3x sohc d16y8
whats up everyone? i have to do a headgasket on my 99 ex sohc turbo. im gonna be doing headstuds also. the motor i have is the d16y8. i was wondering should i use the y8 headgasket or use the d16z6 gasket instead. reason y im asking is because i was thinking of droping the compression ratio.
most likely ill be using the y8 gasket. i just want sum feed back on what u gusy think.
thanx alot
Modified by vtekstorm at 3:15 AM 5/31/2005
thanx alot
honda sells the same gasket for both engines.
.037"
the stock compression is perfect for turbo, especially low boost (assuming you are low boost if you have stock internals...)
.037"
Stonecoldn69
Jun 18, 2012 11:42 AM
kranked91dx
Jan 31, 2004 06:32 AM
