steering rack
Old May 30, 2005 | 05:01 PM
brockscivic's Avatar
Default steering rack
Does anyone know the correct way to adjust the slack out of a steering rack. Ive heard about 5 diff stories about how to do it and whats correct and whats not. I would really love to get this fixed. The slack is from side to side and in the box itself. You can grab either of the front wheels when the front end is on jackstands wiggle the wheel from left to right and hear it "clanking" inside the box.
Old May 30, 2005 | 05:34 PM
Default Re: steering rack (brockscivic)
this ish moves fast...bump for a reason i almost wrecked on I40
Old May 30, 2005 | 05:35 PM
e jay one's Avatar
do you have power steering? maybe your rack is shot.
Old May 30, 2005 | 05:40 PM
Default Re: steering rack (e jay one)
yeah its power....im getting ready to buy another one but wanted to check first
Old May 31, 2005 | 09:35 AM
so theres no way to adjust it?
Old May 31, 2005 | 10:00 AM
94eg!'s Avatar
#1 Super Guy
Loved
Check to make sure the two U joints in the steering column are not worn out. One is #5, and the other is part of #1. Once they wear, they will cause excess play.
Modified by 94eg! at 8:20 AM 6/1/2005
Old May 31, 2005 | 10:41 AM
Archidictus's Avatar
Unceasing Measure
Also the tie rod ends might need to be tightened a little further down on their shafts. I'm not sure how much adjustability is in them on a Civic, but you can give it a try .
Old May 31, 2005 | 12:25 PM
s1ngle's Avatar
Default Re: (Archidictus)
tie rod ends probably shot.
Old May 31, 2005 | 02:31 PM
kkim's Avatar
you could try this...
https://honda-tech.com/zerothread?id=569090
Old May 31, 2005 | 06:00 PM
Default Re: steering rack (kkim)
thanks guys, that all helped...ill get out there and try it tomorrow
Old May 31, 2005 | 07:17 PM
MajorPayne's Avatar
Default Re: steering rack (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
heres something i just did that helped imensely...my steering column itself was a bit shaky, you could grab the wheel and move it like 1/4" in all directions, didnt feel very solid at all, and it was getting on my nerves....anyways, i loosened #11, then pryed on the bottom of #1, to get the splines to slide further down into #5, once i had #1 forced down into #5 as far as i could, i retightened #11....it worked like a charm, id say for everyone that has even the slightest amt of sloppiness in thier steering, to try this, it was definitely worth it
Old Jun 1, 2005 | 06:20 AM
Default Re: steering rack (MajorPayne)
thats not a bad idea either, i wish i could go out and try to fix this but the weather has to be a bitch...o well ill just see if theres anything else i could do tomorrow
yohimbine
Sep 12, 2013 08:49 PM
vinuneuro
Suspension & Brakes
Nov 21, 2010 11:28 PM
DA9_DAD
Oct 3, 2005 06:55 PM
CivicHB93JDM
Sep 8, 2005 09:00 AM
