HELP ASAP:REAR BRAKE SWAP PROBLEM
my 94 dx swap to si eg disc.
done with swap problem is the passenger side,when i pull me e-brake (8 CLECK) the potor still turning, but the other side good. i adj. the e-brake still same. new pads but never bleed yet. IS THERE A PROBLEM WITH CALIPER? DO I HAVE TO BLEED FIRST BEFORE I TEST MY E-BRAKE?
Did you route them correctly? Did you tighten the adjuster nut?
If theyre new cables, it takes awhile for them to stretch and adjust on their own.
Bleeding doesnt effect the way the cables work. You can move it by hand to check its function
i route them correctly,i ts old stock cable, adjuster nut i double check that. one thing i did i compress little bet the piston bec. its a new pads.
00eddie00(95eg)
Sep 20, 2008 07:23 PM
psychoblue23
Dec 10, 2005 03:27 PM
yeegsr
11
Sep 15, 2004 12:12 PM
