universal O2 sensor
Old May 30, 2005 | 11:40 AM
SpoolinDa's Avatar
Default universal O2 sensor
does anyone know if there are any differences between the universal O2 sensors and a OEM honda o2 sensor.
Old May 31, 2005 | 02:22 PM
Dai_Ca_Vietnam_H22a4's Avatar
Default Re: universal O2 sensor (SpoolinDa)
There should not be. However, I would not risk splicing the wire and reconnecting them. Current flow or ohm could change. In physics, current flow is comparable to water flow. Thinks about this comparision, I would not risk the lost of performance. I would get exact oem replacements.
Old May 31, 2005 | 07:07 PM
SpoolinDa's Avatar
Default Re: universal O2 sensor (Dai_Ca_Vietnam_H22a4)
I'm doing a obd0-obd1 conversion and the harness that is required doesn't have the factory 4 wire o2 sensor clip, so i'm going to have to cut and splice somewhere to convert the 1 wire to a 4 wire.
Old May 31, 2005 | 07:34 PM
PrettyLude's Avatar
if ur asking if you can use it in place of an oem sensor you can, i am right now, and have no problems with it
bam69icp
Oct 21, 2008 08:35 PM
IronQQQ
Aug 25, 2003 02:40 PM
93LSivic
Jun 25, 2003 06:56 AM
