use or replace bolts?
Old May 30, 2005 | 10:53 AM
Suck my DX's Avatar
Default use or replace bolts?
im gonna be putting the head back on my b16 tomorrow and was wondering if it is really necessary to use new head bolts or studs??? i plan on reving to 9k and no higher for the time being...im guessing at these high operating speeds the extra strain put on these motors might be too much for the re used bolts....now im always getting mixed responses...a lot of guys tell me to change em and a lot tell me that they re-used them with no problems...even people who were boostin said they re-used...now i dont mind spending the extra money if i know its gonna save my *** in the long run...any one with firsthad experience please chime in....no hearsay as it tends to get me nowhere
Old May 30, 2005 | 10:58 AM
DeadVet's Avatar
Default Re: use or replace bolts? (AMPYR_one)
buy new ones
Old May 30, 2005 | 11:11 AM
Suck my DX's Avatar
Default Re: use or replace bolts? (1TurboHatch)
might as well...anybody know any good places around 626 or 818...****** autolink sells em for 145 for a b16...i couldnt stop laughin when i heard that
Old May 30, 2005 | 11:42 AM
Kendall's Avatar
Headbolts stretch when used which means that when you retorque them they're not holding as well as new ones. Replace them and save yourself the risk.
And what's done to the B16 that would justify revving to 9k rpm's?
Old May 30, 2005 | 11:46 AM
DeadVet's Avatar
Default Re: (Kendall)
just buy arps
Old May 30, 2005 | 12:12 PM
WestCoRacer's Avatar
I know for a fact that Eric Aguilar re uses his stock head bolts all the time and he has run 9's in an all motor.
Old May 30, 2005 | 01:28 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Headbolts stretch when used which means that when you retorque them they're not holding as well as new ones. Replace them and save yourself the risk.
And what's done to the B16 that would justify revving to 9k rpm's?</TD></TR></TABLE>
jdm b16a
3inch short ram intake
maxbore TB 64 to 62 mm
str fuel rail
B&M FPR
AEBS IM
supertech flat top valves
titanium retainers
dual valve springs
p'n'p head and 3 angle valve job
sk2s2 cams
dc 4-2-1 header
si catback (car is a 91 dx)
VAFC
lol... engine grounding kit
stock block
the car is not running yet so i dont know if i will still be makin power up there...im going down to tune and dyno it by friday...but im sure that i have it built enough to rev to 9k occasionally...its not like im gonna be livin at 9k since it is a daily driver...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestCoRacer &raquo;</TD></TR><TR><TD CLASS="quote">I know for a fact that Eric Aguilar re uses his stock head bolts all the time and he has run 9's in an all motor.</TD></TR></TABLE>
thats impressive...but i know that the previous owner of the car had taken the head off before and put it back on...so i dont know if he overtorqued em and stretched em...id rather just get some arp studs... still anybody know off sum shops around here that got em for a decent price...how is camp1320??
Old May 30, 2005 | 06:15 PM
earl's Avatar
Default Re: (AMPYR_one)
Try Ben at Importparts.com for ARP's
BTW, you will pull the aluminum threads out of the block before you will stretch a head bolt. You can also warp the head from too much torque. Head bolts fine for allmotor, use studs for turbo.
Old May 30, 2005 | 06:29 PM
Suck my DX's Avatar
Default Re: (earl)
hey earl...so ur saying that with my set-up re using the stock bolts would be fine....i wanna get em for peace of mind but at the same time my budget is low and i need a new tranny...so im tryin to get all the info i need
beatontheeznutz
Apr 11, 2012 03:52 AM
RSX_S
Oct 9, 2008 07:48 AM
cioli
May 15, 2007 11:20 AM
strokdnblownb18
Jan 12, 2005 11:16 PM
CRXBart
Mar 3, 2002 10:24 PM
