Weird new problem
Old May 30, 2005 | 08:08 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Weird new problem
Well as all of you know, in order to turn on the headlight to need to click the switch twice. When you click it once, the tail lights and the front signals go on. However, when I click mine once, NOTHING comes on, and when I turn it twice, only the front headlights come on.
All the bulbs are good and no fuses are bad.
Whats my issue?
Old May 30, 2005 | 08:12 AM
civictildeath's Avatar
Default Re: Weird new problem (MugenHonda)
sounds like a wire came loose on the switch
Old May 30, 2005 | 08:22 AM
grafffeener's Avatar
try swapping your combonation light switch with a friend most likely that is the problem.
Old May 30, 2005 | 08:29 AM
nocturnaldragon's Avatar
Default Re: Weird new problem (civictildeath)
Propably the switch but wiring is a close possibility
9thgenidiot
Lighting
Apr 27, 2016 10:26 PM
Etorres325
Oct 31, 2009 06:06 AM
I8Stang
Mar 12, 2009 09:41 PM
gotablk95gsr
Jan 10, 2009 09:14 PM
ogawa_jiei
Sep 23, 2006 06:10 PM
