tranny mount ?
Old May 29, 2005 | 07:18 PM
bbrian's Avatar
Default tranny mount ?
on the ef's whats the name of the thing where the tranny mounts too , i think its called the cross memeber its like a beam that goes across i was wondering if anyone ahs tooken it out before ????/
Old May 29, 2005 | 07:41 PM
EP3_05's Avatar
Default Re: tranny mount ? (bbrian)
On a stock d series engine there are two transmission mounts. One mounts to the front crossmember and one mounts to the passenger side frame rail. I would not suggest removing the front mount since it greatly restrains the movement of the engine. Most B series swap mounts only use three mounts but since they use such a stiff mount insert, the front mount can be discarded.
Old May 29, 2005 | 08:08 PM
bbrian's Avatar
thanks i appreciate that cause some times on ef's i always see no crossmemeber and wonder what people do
Old May 29, 2005 | 08:39 PM
bagpipe goatee's Avatar
you need a crossmember there for the suspension, otherwise the control arms would flap around. but, the stock crossmember kinda sucks so there are tubular ones you can buy, look up traction bars.
fuzzysig
Acura TSX
Jun 6, 2017 09:31 AM
Nova_Dust
Mar 14, 2008 04:40 PM
dafuzzbudd
Feb 15, 2007 09:31 AM
Project-D
Nov 30, 2004 09:51 PM
mingchi69
Feb 20, 2004 08:08 PM
