vtec oil pressure switch problem
Old May 29, 2005 | 04:27 PM
LudeJdm's Avatar
Default vtec oil pressure switch problem
88 hatchback d16z6
chipped p28
obd0-obd1 conversion harness
no plug to go into vtec oil pressure switch
ive been getting code 21 which is vtec spool solenoid...so i rechecked my instructions from the place i got the conversion harness and it says green wire to vtec oil pressure switch and black to vtec solenoid...so today i recheckd my wires and it seemed like my homeboy who did the conversion got the wires crossed and had black to nothing and green to solenoid...so i re did them....i had green go to ground and black to solenoid....the only reason i had green go to ground because i dont have the plug that goes into the oil pressure switch....so i reseted the ecu and checked my codes again...code21 is gone now but getting code 22....is there a way to get vtec working and get rid of code 22 without getting the plug for the switch....remember im using a conversion harness....
Old May 29, 2005 | 05:16 PM
mtber's Avatar
Default Re: vtec oil pressure switch problem (lbautista23)
Yes there is...
To wire vtec w/out vtec oil pressure, piggyback vtec oil pressure off of vtec signal.
Ground vtec oil pressure ground if not already grounded.
Old May 29, 2005 | 09:18 PM
LudeJdm's Avatar
Default Re: vtec oil pressure switch problem (mtber)
cant i just tap the green wire into the black wire near the solenoid or do i have to tap it near the ecu side and ground it on the other side? i would use the paper clip method but i dont know which is d6 because the diagram im using uses ABC...wut color wire is d6?
Old May 29, 2005 | 09:52 PM
LudeJdm's Avatar
http://www.50mod.com/fourthgenhatch/mpfi.html
this is what im looking look at the mpfi side....someone tell me which wire do i piggybank to a6
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
LudeJdm
11
Jun 19, 2005 06:23 PM
LudeJdm
May 29, 2005 09:53 PM
singlecamcrx
Nov 24, 2004 02:10 AM
Vexamus
Mar 29, 2003 08:25 AM
