Fan switch relay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx »</TD></TR><TR><TD CLASS="quote">Is there one and if there is where is it and how can i test it</TD></TR></TABLE>
...i think it's the relay on the passenger side rail...there should be four wires going into it...one of them being a ground. It should be next to the grounding bracket on the same side. As for checking it...I dunno...hope this helps
Fan relay switch (radiator fan) is on the passenger side, just ahead of the air filter box, mounted to the chassis. There are four pins on it, arranged like this:
A C
B D
To test, "there should be continuity between the A and B terminals when the battery is connected to the C and D terminals, and no continuity when the battery is disconnected."
From the '88 CRX Factory Service Manual.
Not sure how you connect the battery to two terminals of a four-pin connector, but that's what the manual says to do...
Mike
A C
B D
Mike
big_jay239b16A
16
May 7, 2015 03:31 PM
boots420
Dec 23, 2007 03:22 AM
