clutch install went bad on gsr
Old May 29, 2005 | 09:27 AM
Pnoyej6's Avatar
* B A N N E D *
Default clutch install went bad on gsr
Damn it sucks it took 1 day to put in clutch but clutch install wen tbad. Problems are i can engage in gear. I have to force it to engage. Axles were a bitch. We are thinking maybe the axles are not in all the way. We were also unable to bolt the i believe the front sway bar. The bolt was hard to reach the top bolt because it was hanging down. Please can anyone help. We fill with almost 3 quarts of manual transfmission fluid. What can be wrong? We installed exedy stage 1 clutch. Im gonna get it towed and bring it to a shop because its too much hassle. I can put it in gear for some reason and when i do with a lot of force, it boggles a little when moving.
Old May 29, 2005 | 10:03 AM
AK94GSR's Avatar
Default Re: clutch install went bad on gsr (pnoytegn707)
well first u dont need to unbolt the swaybar, u dont even need to touch that.
and of course the axles are always a bitch. you'll know if u got them in all the way
but if they are not will not affect the gear selection
did u use a clutch alignment tool and did u make sure to install the disc correctly??
Old May 29, 2005 | 11:26 AM
Racermech's Avatar
Default Re: clutch install went bad on gsr (AK94GSR)
The tranny should only take 2.2 qt.
Does anyone think too much fluid couls be causing this???
Old May 29, 2005 | 12:35 PM
accord91h22's Avatar
Try bleeding the slave cylinder?
Old May 30, 2005 | 08:47 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (accord91h22)
yes we use the alignment tool with throwout bearing. Im thinking it could be the slave cylinder missing 1 bolt or maybe we put too much fluid. we put almost 3 quarts honda manual tranny fluid. How do i bleed the slave cylinder??
Old May 30, 2005 | 09:17 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (pnoytegn707)
the only thing i can think of is we didnt bleed the clutch slave cylinder. Could this be the problem or is it required when doing clutch install.
Old May 30, 2005 | 09:32 PM
JoeG86's Avatar
yea dude try bleeding em
Old May 31, 2005 | 04:08 AM
Default Re: (JoeG86)
Well you should only have to bleed it if you disconnected it. Have someone in the car pump the clutch pedal while your out at the slave cylinder have them hold it and you let loose the bleeder valve on the slave. Tighten it back up and have them pump and hold it again and so on and so forth until you have good pressure.
Old May 31, 2005 | 06:21 AM
bosco500's Avatar
Default Re: clutch install went bad on gsr (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">The tranny should only take 2.2 qt.
Does anyone think too much fluid couls be causing this???</TD></TR></TABLE>
Its pretty much impossible to put in too much fluid in the tranny. It starts leaking out when its full.
wonderingpanda
May 1, 2015 07:07 PM
OhBai
Jan 21, 2012 06:58 PM
Kidnkorner
Honda Civic (2006 - 2015)
21
Aug 21, 2008 09:52 AM
90hbvtec
Apr 20, 2006 12:18 PM
Mr. Vapor
Aug 27, 2001 04:00 PM
