HELP with half-sized radiator and FMIC in 88CRX.
Old May 29, 2005 | 08:47 AM
88crxhfb16's Avatar
Default HELP with half-sized radiator and FMIC in 88CRX.
I noticed my FAL is pulling air from inside the engine compartment through my radiator and pushing through my FMIC. Isnt this backwards? seems it is going to heat the air inside my intercooler. sonovabitch. anybody? help?
Old May 29, 2005 | 09:01 AM
beyondspexj's Avatar
if its doing that, reverse the wires and the fan should turn/blow the other direction
Old May 29, 2005 | 09:02 AM
ps any pics of the fmic?? or font shots with rad?
Old May 29, 2005 | 09:54 AM
88crxhfb16's Avatar
Default Re: (beyondspecs_jamar)
yeah, here's one
Old May 29, 2005 | 09:57 AM
gutted-dx's Avatar
Make it so the fan blows not sucks, switch the wires around
Old May 29, 2005 | 10:06 AM
88crxhfb16's Avatar
Default Re: (gutted-dx)
so cut the wires, where the plug is and solder them back reversed?
Old May 29, 2005 | 12:40 PM
88crxhfb16's Avatar
bump
Old May 29, 2005 | 12:42 PM
redzcstandardhatch's Avatar
something different
Default Re: (88crxhfb16)
yes. reverse the wires.
or flip the fan around
Old May 29, 2005 | 12:43 PM
Nay's Avatar
Nay
if the fan blows through wont it push hot air into the engine bay?
Old May 29, 2005 | 12:51 PM
Joebroni's Avatar
Yes and that's what it's supposed to do. Otherwise it will push the oncoming air when you are moving back out from the radiator area (in an exaggerated form) and not promote cooling.
And yes, that fan is mounted on the opposite side of where it is to be mounted on a radiator, so you just need to put power on the opposite of where you are currently putting it (aka switch the wires around).
Old May 29, 2005 | 01:25 PM
88crxhfb16's Avatar
Default Re: (Joebroni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni &raquo;</TD></TR><TR><TD CLASS="quote">Yes and that's what it's supposed to do. Otherwise it will push the oncoming air when you are moving back out from the radiator area (in an exaggerated form) and not promote cooling.
And yes, that fan is mounted on the opposite side of where it is to be mounted on a radiator, so you just need to put power on the opposite of where you are currently putting it (aka switch the wires around).</TD></TR></TABLE>
cool thanks, yeah I have no choice but to run it this way. Turbo would be Hella in the way to try and run it on the other side.
Old May 29, 2005 | 06:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, here's one
looks good and good idea on mounting the fan since your turbo is in the way. but yes, your only solution is to switch the wires around. with you keeping the wires as it came out the box, the fan was spinning the way it was supposed to IF u kept it in the engine bay, but since you switched it around you were supposed to swap the wires also
Old May 29, 2005 | 08:04 PM
notfastenough's Avatar
If it uses a plug, you could see about de-pinning the plug and switching them to keep a cleaner install. Just a thought...
Old May 29, 2005 | 08:05 PM
bagpipe goatee's Avatar
2 things. you can just pull the pins out of the plug with a small screwdriver, and switch them that way, rather than cutting them.
and the fins on the fan are designed for turning it one way, they won't move as much air the other way. just keep that in mind when you let it idle on those hot days.
Old May 29, 2005 | 11:20 PM
speeddave's Avatar
Default Re: (bagpipe goatee)
nice setup... any pics w/bumper on?
some fans are designed to both pushers and pullers.
Old May 29, 2005 | 11:53 PM
lococoin's Avatar
Default Re: (speeddave)
you must have a monster front bumper. I had to hack the **** out of mine just to fit a jrc 6 inch into my 90 hatch.
Old May 30, 2005 | 06:09 AM
Did anyone else notice the COMPLETE lack of a bumper support? Damn dude with all that intercooler, who needs a bumper lol.
Old May 30, 2005 | 07:45 AM
88crxhfb16's Avatar
Default Re: (notfastenough)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">Did anyone else notice the COMPLETE lack of a bumper support? Damn dude with all that intercooler, who needs a bumper lol.</TD></TR></TABLE>
bumper still retains all original bolts. Just has a big hole in the front
Old May 30, 2005 | 07:47 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">nice setup... any pics w/bumper on?
some fans are designed to both pushers and pullers.</TD></TR></TABLE>
Old May 30, 2005 | 08:10 AM
Joebroni's Avatar
LoL, not much of a sleeper.
Old May 30, 2005 | 09:25 AM
slowpokesi's Avatar
makes me miss mine alot~!
Old May 30, 2005 | 11:28 AM
88crxhfb16's Avatar
yeah, i know, any ideas on how to cover it up. who makes an aftermarket frnt bumper that will cover it?
Old May 30, 2005 | 01:30 PM
b16_madman's Avatar
Prolly a WW one. Heck paint it black with the proper paint. Or keep the buck tooth look, some VW's have that on them. It's fun to look at.
Old May 30, 2005 | 03:01 PM
speeddave's Avatar
Default Re: (B16_madman)
since you have no bumper support, why not raise the intercooler up so that it doesnt hang below the bottom of the bumper. that way you could leave the bottom portion of the bumper intact. it would look and fit fine then imo.
Old May 30, 2005 | 03:11 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default Re: HELP with half-sized radiator and FMIC in 88CRX. (88crxhfb16)
What radiator is that?
user 72830283
Mar 1, 2015 02:40 PM
julianbc2
Jun 28, 2010 12:31 PM
PhantomX
Feb 9, 2009 07:00 PM
88crxhfb16
May 29, 2005 10:05 AM
