is a EBC really better than an MBC?
Old May 28, 2005 | 08:58 PM
streetrage's Avatar
Default is a EBC really better than an MBC?
Do you think that a electronic boost control will work better than a manual boost control? I have been through 2 greddy profecs (one A and one B) and neither seem to work right.. If I hook up my wastegate directly, it runs 7 psi just like it should.. My car is a drag car, so I don't need to be able to adjust my boost all the time, and the EBC's make my engine compartment look all cluttered... Should I just go MBC and save the hassle, or does the EBC really make the boost respond better?
What do you guys and girls think?
Alex
Old May 28, 2005 | 09:43 PM
turtle-eg's Avatar
Default Re: is a EBC really better than an MBC? (streetrage)
If you only need a single stage controller, I would just use a mbc.. set it, tune it, and forget it.... no electronics to worry about.
Old May 28, 2005 | 09:44 PM
s2kdre's Avatar
Default Re: is a EBC really better than an MBC? (turtle-eg)
the ebc just reduces spikes and creeps
Old May 28, 2005 | 10:52 PM
Drew Peacock's Avatar
Default Re: is a EBC really better than an MBC? (jdmhonda)
They aren't perfect but I love the fact that you can set the over boost function so it will bring boost back to stock if you over boost, with a manual BC that could be the end of your engine....
Old May 29, 2005 | 05:11 AM
Rod.'s Avatar
Default Re: is a EBC really better than an MBC? (turbozxi)
bump for more info
Old May 29, 2005 | 08:39 AM
mike1114's Avatar
Default Re: is a EBC really better than an MBC? (redturbocivic)
if your gonna set it and forget it and never change it then go with a manual. I have a hallman manual for over two years, holds the boost completly solid and I never have to worry about it. Its hidden down by my clutch master cyl so you don't even see it.
Old May 29, 2005 | 09:23 PM
streetrage's Avatar
cool thanks, Im gonna just use a manual one... It will make my engine bay look alot cleaner than with all the hoses from the electronic BC....
delslo93
Aug 15, 2006 04:50 PM
5thGenCivicKid
Mar 26, 2005 11:40 PM
zseeanz
Nov 11, 2003 07:50 PM
lsvtecvx
Jun 4, 2003 03:34 AM
tsi_turbopwr
Aug 27, 2001 03:23 PM
