BC stage 4 for my setup? opinions welcome SEARCHED!!!
B16 head + block
85mm 13.4 comp wiseco customs
eagle rods eagle 3.334 l/w stroker
TWM Itb'z
Alaniz P+P head flowing great CFM w/ pro chamber work 44.6 cc volume
Should produce around 1.925 L
Running PORTFLOW valvetrain, stock valves.........
what do you guys think ? Im NOT running rocket cams, I like my valvetrain and im not changing......
Im assuming from the massive amount of research ive done skunk2 stage 3's will be similar around 9k but produce less mid-range......... Im dragging this and need power from 7-9k
ive got it down to
bc4's
jun 3's
or
skunk 3's
right now im running a * custom grind * web-cam with an odd combination of Skunk2 stage 2 and stage 3 lift and duration.... im going to tune it with them first since ive had them for years then change to this new cam im trying to have Honda-tech help me decide on, any information please share - if you have first hand experience that would be better then commenting on something you know nothing about so haters refrain, thanks
TWM Itb'z
ive got it down to
bc4's
jun 3's
or
skunk 3's
Well I know the buddy 4's with the A on the ends work well.. Another good choice is the skunk pro-1 cam .. I beleive Donf has done a back to back on all 3 of those on the same motor(skunk3.buddy4/pro1) Tell him your power band required and he can give you a run down. The buddy 4's beat the sk3 on my motor but not on his. I'm talking peak onny not midrange..
sweet, thanks for the quick reply bro---- I am a little sketched out about the whole A-B stamp thing but what am I supposed to do ? kteller.com has great pricing on the cams and im not sure which kind he sells?
can the pro-1 make power from 7-9k? its an all motor drag car, I care little for anything under 6k Im still in a state of confusion
Ill P/M don, thanks again,
keep posting people!
Ill P/M don, thanks again,keep posting people!
C2Imports
May 30, 2005 06:04 AM
