Big Problem
Old May 28, 2005 | 04:48 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Big Problem
Yesterday, I got pulled over for not having working tail lights.
I have an alarm and that makes the tail lights work, so I know the bulb is good.
Any ideas, I checked connections around the fuse box and came to no solution.
please help
Old May 28, 2005 | 04:57 PM
neutron91's Avatar
Default Re: Big Problem (MugenHonda)
how long have you had the alarm?... ive seen some half *** alarm jobs cause this... i would take it back to whoever installed the alarm and have them look over it
Old May 28, 2005 | 05:21 PM
MugenHonda's Avatar
Default Re: Big Problem (neutron91)
Anyways just the past week out of nowhere my instrument cluster deicded not to work.
Then my tail lights don't work and my fron signal lights don't work.
I know the bulbs are all good because when i click on my alarm, they all light up.
However when I go to turn on the lights, especially at night time, all I have go on is the headlight.
My tail lights don't go on, but when I press the brake, they go on.
my front signal lights don't go on, but when I turn on the hazards, they go on?
This is killing me, what can be causing this?
Here is a better description. The alarm has been in for 6 years, with no problems, I got the viper alarm put in when i got the car.
Everytime I click the alarm to open the doors, the tail lights and the front signal lights go on meaning the bulbs are good and the alarm isn't the faulty thing.
Now the wiring, I have no idea?
Old May 28, 2005 | 05:46 PM
SPOON_FED_DC_2's Avatar
the instrument cluster lights didn't work or the whole thing didnt' work i had that problem in my gsr before it was a fuse 10 amp or 15 amp fuse i replaced it and my tail lights guage cluster lights worked fine try that hope it helps. shoot
Old May 28, 2005 | 06:08 PM
neutron91's Avatar
Default Re: Big Problem (SPOON_FED_DC_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_FED_DC_2 &raquo;</TD></TR><TR><TD CLASS="quote">the instrument cluster lights didn't work or the whole thing didnt' work i had that problem in my gsr before it was a fuse 10 amp or 15 amp fuse i replaced it and my tail lights guage cluster lights worked fine try that hope it helps. shoot</TD></TR></TABLE>
yes sir... had that happen in my old crx
Old May 28, 2005 | 07:03 PM
ProSlow07's Avatar
Ditto, in the 2K4 Lancer for me, I got it installed about 2 months later I had a hella ticket for no tail or corner lights during evening hours.
Old May 28, 2005 | 07:07 PM
Will_the_Thrill's Avatar
Default Re: Big Problem (EgHatch07)
check all connections...wires could have messed up, check fuses
Old May 29, 2005 | 10:36 AM
MugenHonda's Avatar
Default Re: Big Problem (DSM2fastEG2clean)
my fuses are perfectly fine and only the lights to the cluster and instrument dash don't work
Wiretaju
Jul 2, 2011 12:34 PM
00ekcoupe
Audio / Security / Video
Nov 7, 2008 07:41 AM
g0tsilkk
Mar 25, 2006 08:44 AM
slickrc
Sep 9, 2004 08:00 AM
Kenshin!
Jul 24, 2003 03:27 PM
