what gear is this on my b16a y21
i took apart my tranny today to replace my input shaft bearing
after openning up the casing i saw this gear all grinded up
which gear is it
i think its 2nd or reverse
the gear im talking about on the pic is the 2nd gear on the counter shaft
Modified by komat at 8:38 PM 5/28/2005
Modified by komat at 8:39 PM 5/28/2005
which gear is it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91sit »</TD></TR><TR><TD CLASS="quote">I"m thinking it's reverse, Since 1-5 gears are all helical cut i believe. Reverse would be your only straight cut gear, which is why it goes szzzzzzzzzzzz when you use it.</TD></TR></TABLE>
from what he stated the reverse is the only straight cut gear. which is true
while iw as replacing my bearing i was messing witjh the shifter. the shifter idle gear went right into. the guy who owned my motor in japan must be in a hurry always or some ****. those are some pretty nasty reverse grind.
also if you plan to open the tranny on a b tranny. practice couple of times putting on the case. becuase it took me 20min just to wiggle the casing in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elise »</TD></TR><TR><TD CLASS="quote">yeah it is reverse, as well as a syncro sleeve.. hmm thats shitty :\</TD></TR></TABLE>
where is the syncro sleeve that is fucked??
the thing right above the reverse?
092eg6
Transmission & Drivetrain
Dec 2, 2009 01:33 PM
