Question about foglights?
I know something similar has already been covered but that is not what I am trying to do. I want my 99 OEM foglights to be on with my corners but I dont want to do it the way covered in this thread: https://honda-tech.com/zerothread?id=707193 because alot of people have had problems with sutff. I was wondering if there is any was else to do it? Someone told me that the fogs can be hooked to a constant 12v power source? I am not sure if that can be done with OEM fogs.
you can tap in the corner light harness or find a 12 volt switched source when you turn on parking lights. there should be a slot in the fuse box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you can tap in the corner light harness or find a 12 volt switched source when you turn on parking lights. there should be a slot in the fuse box</TD></TR></TABLE>
How would I find out if there is one in the fuse box? Use a test light?
What wire would I connect to the 12v source?
4DRmafia
19
Aug 28, 2006 01:44 PM
Solscud007
Jan 4, 2006 04:50 PM
oc_civic
May 23, 2004 12:45 PM
