running lean according to plugs... will retarding timing help?
Old May 28, 2005 | 03:06 PM
brokenojoke's Avatar
Default running lean according to plugs... will retarding timing help?
95 couple ex with JDM b18c
All ITR valvetrain, cams, and intake mani.
Stock p28 obd1.
It's my understanding that the ECU would richen up the mixture if it sees that it's running lean. All four of the plugs are pretty white, with no brown at all.
This is my daily, and within a month or so, I can get a couple of dyno pulls and an adj. fpr to help it out. Till then, I need a free solution if there is such a thing. A few buddys told me to retatd the timing.
Good or bad?
Woulud anything else help??
Old May 28, 2005 | 03:23 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: running lean according to plugs... will retarding timing help? (brokenojoke)
Jesus christ, stock p28, thats made to run a sohc civic, get that thing chipped before you ruin your motor.
Old May 28, 2005 | 04:07 PM
Default Re: running lean according to plugs... will retarding timing help? (PURPLETERROR)
Hang on, it's gotta be the b17's edu.... let me check on that ECU part number and get back wit ya.
Old May 28, 2005 | 04:12 PM
P72..... my bad
Old May 29, 2005 | 07:55 AM
bump
$LiLPooky$
12
Nov 16, 2009 01:04 PM
s2k4life2861
Apr 30, 2007 08:32 PM
91integraLSVTEC
Jan 3, 2004 05:48 PM
Pikachu
Oct 21, 2003 06:23 PM
blykins
15
Mar 13, 2003 06:49 AM
