crx is burning oil
Ok i just put in a whole 4 quarts like 2 - 3 weeks ago in my car. Yesterday night when i was cruising home from my friends my oil light started flashing, i pulled over to check it it was like 5 cm left according to the stick. What should i do? Oil change??
Also white smoke is comming out of my exhuast now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness »</TD></TR><TR><TD CLASS="quote">Ok i just put in a whole 4 quarts like 2 - 3 weeks ago in my car. Yesterday night when i was cruising home from my friends my oil light started flashing, i pulled over to check it it was like 5 cm left according to the stick. What should i do? Oil change??
white smoke is coolant....
</TD></TR></TABLE>white smoke is coolant....
Due a compression test to see if the rings or valve seals are bad. Your in Illinois so if you need any help youcan contact me
The white smoke is probably signs that your headgasket is going.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness »</TD></TR><TR><TD CLASS="quote">What kind of help can i get? LoL</TD></TR></TABLE>
IM me if you need help
your floor board is gonna fall out!!!!
anyways get a compression test and leakdown test done. sometimes compression will be fine but valve seals will be bad. as said before white smoke=usually coolant.. so keep an eye on your coolant overfill and watch for overheating!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuckingfuts »</TD></TR><TR><TD CLASS="quote">your floor board is gonna fall out!!!!
anyways get a compression test and leakdown test done.keep an eye on your coolant overfill and watch for overheating!</TD></TR></TABLE>
yeah ima have to get one of those done when i can get the money. haha.
Also im gona be doing a whole check up and shizzle done on the car. -=D don't want it shutting down on me kuz of low coolant or something loose or w.e just need a jizzob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">Due a compression test to see if the rings or valve seals are bad. Your in Illinois so if you need any help you can contact BrokeAssPinoy
The white smoke is probably signs that your headgasket is going.</TD></TR></TABLE>
Bring it to me! I have the gauges I just need to look for them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">
Bring it to me! I have the gauges I just need to look for them</TD></TR></TABLE>
To bad I never recommend you. explictness I have all the tools handy to do a compression test and I will walk you threw it if you need it. I usually do compression test for free for my customers. Since there is not really any big time labor involved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">lol he's my homie man, go ahead you can have him hahaha </TD></TR></TABLE>
it came off wrong on how you quoted me though
haha doesn't matter who i go to. As long as i get it done. Mike if u can get the tools help me out. -=D If u can't then i will go to 90blackcrx. but can this be done by this weekend?
chickenandpickles
16
Sep 11, 2005 01:29 PM
vmm
May 19, 2005 11:54 AM
